I've been lucky enough to be able to move to a large-than-cupboard-sized workshop, and one of my first tasks was to make a new (version 3) router table.
I do almost everything on my router table (which is why it's the only tool you can see in the 'shop), and I thought I'd treat myself to a "manufactured" router table insert plate, rather than using the "hole in a bit of plywood" approach I've used before.
I've always found TrendUK to be a reliable company - I like their bits and they ship to Portugal with no fuss. So I thought I'd buy their plate…
Full specifications of which you can find here.
Feature 6 on the list is…
"Moulded with slight crown (0.8mm) for distortion free cuts."
They're right - it isn't flat - my straight edge rocks slightly, but nicely, when on the crown of the plate.
So - I have 2 questions…
Thanks in advance for the wisdom I know will be brought to bear here on my behalf.
- Can someone explain to me how a non-flat plate aids in producing "distortion free cuts"?
I just find it weird to use - not very very weird, just a bit weird - and I'd like to know if there's some benefit (I can see the insert rings could be useful, but I don't use big bits and a single sized hole was never an issue for me), and if so, how I reap that benefit, before I remove it and just drill a hole like I've done before. - Aside from the removable rings, are router table insert plates really any better than "just a hole", and if so, why?
