Strange bandsaw problem, wheel alignment
2 reading
348 views 34 replies 18 participants last post by  imaginationuninc
#1 ·
Hello!
I have a big problem installing the blade on my band saw. It's a Axminster Workshop AW2606B.
I have had the saw since last spring and I feel that the problem has gotten worse. When I change the blade, I place the new blade in the center of the upper and lower wheels.
Then I spin it a few turns manually to check how the tracking is. After just a couple of turns, the blade is severely misplaced on the lower wheel. The blade slides towards the front of the saw and is almost falling off the lower wheel.
What is wrong? I have tested several different blades in different dimensions.
I suspect that the wheels are not aligned? But how do I check? Do I dare adjust the lower wheel?
Thank you for your help as I am a beginner in the subject.
#2 ·
Is the lower wheel loose when you grab it and give it a shake ?
Could be bearings, bad tires or even the upper wheel bearings and tires.
I don't know of any BS that has an adjustable lower wheel.
#4 ·
Is that saw even sold in the USA because I’ve never heard of or seen one. I don’t think it’s fair asking Americans about a euro made bandsaw what Are the chances our machine problems will be the same? If it’s new push the warranty with your concerns.
#8 ·
thanks for your input :)
Sure, I don't have the best saw in the world, but I don't have the worst either. You might still think you should be able to make the blade stay on the wheels.
I have tried adjusting the tracking and making sure nothing is loose.
it will probably be a warranty issue but I want to rule out a bad setup before I contact the store.
#9 ·
Generally, you track the blade on the upper wheel and it does not matter where the blade rides on the lower wheel as long as it's not falling off. How are you adjusting the tracking? Have you watched the obligatory band saw tune up video?
Band Saw Clinic with Alex Snodgrass
That is for a bandsaw with crowned wheels, and typically the wheels being co-planer is not something that is required. Have never heard of the saw you have so YMMV.
#11 ·
I wish I could help. I set up my Rikon following the Snodgrass video. I backed off the guides completely, tensioner and then adjusted the top wheel tracking. Best I can suggest is to carefully check for loose or bent parts.
Of course, calling the mfg would be next. Goid Luck
Sorry about the snarky comments made by some....not helpful.
#15 ·
Bandsaws are fairly simple machines, no matter what part of the world it is in.
I can think of a few things that could cause that based on my experiences reconditioning a few older ones.
A bad bearing in either of your wheels, failure of the tensioning mechanism, a wheel that has a loose set screw and the wheel has walked out past normal placement on the axle, badly worn rubber on the tire, or a bad blade. A few minutes spent in thoughtful troubleshooting is time well spent.
I've experienced all the above except for the failed tension mechanism. All were resolved easily.
If you have a dull blade that otherwise worked well you might put that back on and get the saw adjusted back to a point that it stays on the wheels while running. Then change that blade for a new one keeping the same adjustments.
#16 ·
DO NOT ADJUST THE BOTTOM WHEEL!!!! NEVER EVER!!!! Its a rabbit hole you will never get out of.
Bandsaw blades are not supposed to be central on both wheels. The top wheel is tilted to allow the blade to be tensioned and adjusted within the guides movement range. As long as the blade isnt actually off the tyre on the bottom wheel, youre within specs.
Axminster is a good brand, sold by Axminster tools in England but not actually made there. My axminster 350 has been a fantastic machine for over 10 years now.
Blade guides are the most important part. take all of the guides well away from the blade, adjust the top wheel to get tension (with the machine disconnected from the power, you should have the guard all the way up, grab the blade in the middle of the free space with finger and thumb and try to twist it. It should move about an 1/8th of a turn, no more, no less) Once you have the tension right, use the top wheel adjust to get the blade running in the centre of the table cut out slot. Move the rear guides forwards enough that they are about 2 mm free of the running blade. Then move the side guides to the blade so that they are only just NOT touching.
Once the machine is running the rear guides are there to stop the blade from moving back under cutting pressure and getting the teeth squashed by the side guides. If that happens you will need a new blade.
#17 ·
I've just looked up that model, its the new version of my 350. That dust connector was the result of a long conversation between axminster and myself as mine had two completely different collection ports and the the dust removal was poor to say the least.
Axminster might not be well known in america, but is a european leader.
#19 ·
I am very grateful for your help
Found this information from a manual on a similar band saw.
I have understood that one should be careful when adjusting the lower wheel. But this instruction feels clear and addresses the exact problem that I have had..
Would you dare to make this adjustment?
#20 ·
It should have an adjusting bolt that you turn till it almost touches the ar mm it's on ,wish I had a picture to show cause im terrible at explaining,lol im gonna search my old pics of my big bandsaw
#21 ·
I agree with @MrUnix re: coplanar wheels. I don’t think any bandsaw I’ve owned had had coplanar wheels, including my latest, a Laguna.
As many here know, I am not a fan of Mr. Snodgrass, mainly b/c he causes people to believe there’s something wrong with their saw, when there isn’t. And because he teaches people “drift” is something you can eliminate rather than adjust for.
I tried to “Snodgrass” my Rikon, not only could it not be done, in the process I discovered the wheels were not coplanar. It has the same type adjusting mechanism as the OP. I called tech support. The answer I got was the lower wheel is set at the factory and should never be changed.
I recommend you follow @sunnybob ’s advice!
The only time I’ve seen it be an issue is using a wide blade.
#26 ·
I've had 2 bandsaws over the last 11 years. the first was a piece of crap that just would not cut true. I fought it for a year before admitting defeat (I have been a mechanical engineer for most of my working life). The second (my axminster) came with a few problems, but they were easily solvable with help from axminster. No, on a new machine, I would never move the lower wheel. But if you feel you have to, then mark each and every connecting point on all bolts and rods in relation to the body of the machine so that you can be quite hopeful of returning it to the original position when you find out you havent solved the problem.
#35 ·
The manual on the Rikon and Grizzly go through the process of adjusting the lower wheels. Based on my first hand experience, it is for good, if rare, reason.
To be clear, they talk about tracking issues, such as the blade moving off the lower tire with it running centered on the upper tire.
. . . .No, on a new machine, I would never move the lower wheel. But if you feel you have to, then mark each and every connecting point on all bolts and rods in relation to the body of the machine so that you can be quite hopeful of returning it to the original position when you find out you havent solved the problem.
#28 ·
Sounds like you’re on the right track suspecting alignment. If the blade consistently walks forward on the lower wheel, the wheels are likely not coplanar. You can check this by laying a straightedge across both wheels (with the blade off) and seeing if they line up. If not, Alex Snodgrass or Sawblade.tv can be your hero.
#29 ·
I never worried about making bandsaw wheels co-planer either. If the bandsaw cuts well through its useable tracking range, what is the problem?
Snodgrass' video can be helpful as long as you keep an open mind. Be flexible and do not treat it as the "only way."
What works better for me than Snodgrass is centering the blade over the crown, rather than centering the gullets over the crown. The blade aligns best with the miter slot and fence when it is centered, too. Drift is not a serious issue on my bandsaw.
#31 ·
Whenever I tension a saw the blade will move as it is tensioned. If I bring the blade to a higher tension the bandsaw frame will deflect more. The upper wheel will dip and rotate some. When it rotates the blade will change position.
#32 ·
Soooo, getting back to your original question. I’ve never had a bandsaw that I had to set up the bottom wheel, BUT, every new one that I or my friends have purchased has a section in it on how to check for it being in line with the upper. This leads me to believe that the manufacturers are providing a pathway for the consumers to fix their own problems. With that being said. I would definitely contact the manufacturer and speak to someone in their service department, if possible. Try to identify the real source of the problem, this may take a while, as in my experience, the days of the grizzled old employee that knows everything, is long past. You’re just as likely to get ahold of a person with very limited experience that is getting paid peanuts as you are someone who really knows their stuff.Factory setup only means that someone followed an instruction sheet and maybe, good enough was in the forefront of their vocabulary. As for doing adjustments and repairs, that depends on you. Are you a mechanical engineer, a master mechanic, someone who doesn’t even own a screwdriver, or a person in between. I’ll tackle anything, AS A LAST RESORT, but that’s me. You need to decide for yourself. Good luck!
#33 · (Edited)
What Mr Unix said, with occasional conditions.
I always shoot for centering the gullet on the upper blade. However, with large blades (e.g., 1"), I can only go so far doing that. Still, even a little in that direction helps limit drift.
As to lower blade adjustments, MANY saws have such adjustments.
I have a 14" Powermatic. It doesn't have the lower adjustments. Then I bought my buddy's 14" Rikon at a killer price and discovered the lower wheel was set wrong at the factory. The blade kept pushing in, against the case. I had to resort to the adjustment chart, as posted above. What a pain. It took a few days to get it dialed in.
The Rikon ticked me off enough, once I got it aligned right, I sold it for what I had in to it (gone in 3 days) and bought a 17" Grizzly. I was surprised to see it had lower adjustments too. Fortunately, it was spot on.
My Powermatic runs like a top. That only happened once I abandoned that co-planer nonsense and let the bottom ride where it wanted to (If not hanging off the wheel or causing a blade to rub on a case, it's good to go). Again, I try to run the gullet at center on the top wheel and call it a day.
