Well, the plate making actually went smoother than I thought, although I did forget to drill one hole. The main reason I bought the Milwaukee was to avoid buying a lift. It provides a top access hole to raise and lower the bit… and that is the hole I forgot, DOH!
-- Tom, Central New York
11 comments so far
Will Mego
home | projects | blog
307 posts in 3677 days
#1 posted 03-30-2008 02:06 AM
That is mucho cool. I wish I had that! Plus, I could watch that tool spin for hours….
Bet you could get a sideline making us router plates for cash…I can’t seem to spot any that really catch my eye. Some don’t even look flat! Yours is nice!
-- "That which has in itself the greatest use, possesses the greatest beauty." - http://www.willmego.com/
27250 posts in 3787 days
#2 posted 03-30-2008 02:59 AM
Tom,
Your talents never cease to amaze me. That is a very nice plate you have made. I can’t wait to see the finished table.
rikkor
11295 posts in 3839 days
#3 posted 03-30-2008 03:28 AM
Wow.
teenagewoodworker
2727 posts in 3733 days
#4 posted 03-30-2008 03:44 AM
wow that is amazing. i wonder if i have any machinist buddies who could do that. hmm…... great job and thanks for the post!
GaryK
10262 posts in 3953 days
#5 posted 03-30-2008 07:11 AM
Great looking plate. Nice job machining it.
windpro
3 posts in 3587 days
#6 posted 06-25-2008 03:21 PM
What kind of milling bit did you use to ream out the shelf on the aluminum hole you cut
ww_kayak
70 posts in 3690 days
#7 posted 06-25-2008 04:30 PM
It is a boring head. Basically a straight vertical bar(boring bar) with a piece of carbide on it is attached to the head. The bar is offset from the centerline of the head in small increments. This was not the best tool to make that shelf with, but it worked. Basically I moved the cutter out 30-50 thousands and plunged to the depth of the shelf. Then did it again, and again, and again…
windpro
#8 posted 06-25-2008 07:50 PM
I don’t have that set up yet and it seems too expensive for me to purchase for such a limited use for me. Thanks for the reply
ww_kayak
#9 posted 06-25-2008 07:58 PM
A rotary table would be even better, but I got the cheap import version of the boring head for a whole lot cheaper than the cost of one of those babies.
windpro
#10 posted 06-26-2008 12:39 PM
I have considered trying to rotate the piece but the plate is just a little too large to rotate between the cutter and the trunk of the mill. Where is a good source for the import version of the boring heads?
23841 posts in 3816 days
#11 posted 06-27-2008 04:59 AM
I am envious.
