Mikros Kosmos #20: My first dovetails!
Blog entry by tyskkvinna posted 08-29-2010 04:18 AM 1562 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 19: And we're back Part 20 of Mikros Kosmos series no next part
So the discussion in my last blog really got me thinking and for whatever reason this evening I decided to give dovetails a shot. I’ve never done any sort of locking joinery before… in fact I’ve only even tried mitred joints a few times without all that much luck.
I figured it out.
This is 3/32×1/8 balsa wood. It was just two scrap pieces I thought I’d see if I could actually do it. Determining that, in fact, I could, I set about making the drawers.
Drawing it out helped a lot. Really need a better marking tool but my super fine pencils don’t quite stick and when I tried to mark with my knife I ended up just cutting it all the way through. Er, oops.
My first dovetailed drawer frame! WOOHOO.
And my second.
I only made two tonight. That was more than enough to go cross-eyed. The counter needs four. I cut out the planks for the other two, they just need to be cut for the joints. I tried really, really hard to keep a slight angle to the dovetails so that they wouldn’t be just straight finger joints. And amazingly, it made a big difference! These pieces for the drawers are 3/32×1/4 basswood. Super nice to work with!
I put bottoms on them – nothing fancy just 1/64 basswood.
This is one of the drawers sitting in its spot. I made a little brace so that it sits on that.. just like a real kitchen. (I inspected my own kitchen to see what would make sense)
Of course, the drawers will get proper drawer fronts. Those, I imagine, will be made out of a nice hardwood. Kind of leaning towards padauk..! We’ll see.
I glued the joints together because the wood just isn’t sturdy enough to grip all on its own. I did a friction fit in several places and it still wiggled free pretty easy. Nothing a little CA glue can’t fix. :)
By the way, thanks for the encouragement, guys! I definitely would not have tried this otherwise.
-- Lis - Michigan - -
10 comments so far
View Rob200's profile
313 posts in 3103 days
#1 posted 08-29-2010 04:21 AM
look good for the first time
-- Robert Laddusaw and no I am not smarter then a fifth grader ( and no I canot spell so if it is a problem don't read it ))
View ksSlim's profile
1273 posts in 2823 days
#2 posted 08-29-2010 05:27 AM
Dovetails in thin material, difficult, in thin, soft material extremely difficult. sells one of the narrowist (skinny) chisels that I have found 2mm.
For your work that might be considered large.
Really like your work and attention to detail.
-- Sawdust and shavings are therapeutic
View Dennisgrosen's profile
10880 posts in 3049 days
#3 posted 08-29-2010 06:05 AM
TUUUT-TUUUT from the big whistle :—))
you realy did it
congrats never thought it was possiple , you are officiel in the big leage now Lis
best thoughts
View BertFlores58's profile
1694 posts in 2856 days
#4 posted 08-29-2010 01:07 PM
Your first dovetail is more difficult to make that even I could not figure out how to make a dovetail with such thin and soft wood. Your sucess in doing this way becomes now a challenge to me. Well done.
-- Bert
View BritBoxmaker's profile
4611 posts in 2970 days
#5 posted 08-29-2010 01:27 PM
Beautiful, Lis. Well done. You never know until you try.
View Sheila Landry (scrollgirl)'s profile
9222 posts in 2853 days
#6 posted 08-29-2010 03:18 PM
Holy Moley!!! I look at that and I can’t believe it! That is a wonderful way to do it and it really is a great way to learn the construction of things (I am learning anyway!) This is really a masterpiece in the making. I am thoroughly enjoying seeing the process and the steps you are going through. So many, many details!
You are incredible, girl!!!
Sheila :)
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs ( Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View woodbutcher's profile
592 posts in 4099 days
#7 posted 08-29-2010 03:46 PM
Very nice attempt, with some of the most difficult medium to work with! I might suggest trying a single edge razor blade. I use these alot with great success on lots of detail projects. They are much cheaper than specialized cutting tools and have a good hardness to them. I have actually used pliers to break them into different sizes for extreme detail work in the past. Really good tool material. Be sure to have those safety glasses on if you try to shape the blades. Congratulations on the continued necessary patience-Keep on keeping on!
Ken McGinnis
-- woodbutcher north carolina
View tyskkvinna's profile
1310 posts in 2919 days
#8 posted 08-29-2010 04:08 PM
Thanks all! :)
I did use a single edge razor. :) I found it the easiest – I started with my normal knife but found it to be just too big and heavy for this delicate work.
It is a great way to learn! By the time I work my way up to real furniture it’ll feel like a luxury- getting a knife into the notches to cut it out was difficult at best.
#9 posted 08-29-2010 04:38 PM
I found that too, Lis:
I do so much ‘small’ work that when I do the regular sized stuff, it is a piece of cake. I laid a variable width maple floor a couple of years ago with a couple of guys (not tongue and groove, we laid it end to end and made plugs for it). They were surprised/impressed at how well I could cut the boards to length with the miter saw and do all the work involved with it. I am used to using a blade the thickness of a hair to split a 1 pt line. Cutting with a miter saw is easy. The man in charge shook my hand when the job was done and told me I could work with them any time. I don’t think they though a ‘girl’ could do a good job. I loved it and thought the job was really fun! I can see you having the same success on regular sized furniture. What you are doing I believe is much harder than that! It will probably be a breeze! Great job again!
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3646 days
#10 posted 08-31-2010 05:01 AM
Amazing Lis! Well done. A real impressive model, with real dovetails no less!!!
