Works in Progress #1: Clockwork
Blog entry by tyskkvinna posted 06-22-2010 04:05 AM 1409 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Works in Progress series Part 2: beatin' up my oak »
As I have mentioned in a few places, I am in the middle of moving my workplace. Which is where my shop is. It’s going to be at LEAST another month before I get to unpack, maybe more. Things are in an annoying limbo.
I went down to the old place today to bang out a few things. I had more ideas in mind but they have to wait. Humidity and I are having a raging battle and I’m on the loosing side of the war. Sigh.
But, I had a stack of designs I had cut earlier that needed some basic work done – pocket cut-outs and some keyhole hangers.
My pile back home at the end of the day.
You’ll have to see what I do with them… I have 2 finished pieces, one of which will be going up tomorrow. The other, in a day or two.
Of the 18 pieces I brought home with me today, 2 are relief sculptures (of the same design but different woods/finishes), 5 are carvings (made to look like lino-types!) and the remaining are clocks. I like the clocks…
Could I get some wood ID help from you all?
I initially thought this was cherry – is it? I paid closer attention to it today and noticed the lines – spalting?
Same board. This was the end bit of it. The board was initially something like 6-7 feet long and I cut it into smaller pieces.
If you get your glasses on and squint real hard (or click through and view “big”, and then squint) you can see some figure in the corner of that (also same board) that looks kind of like the figure usually seen in oak. It’s all over this board, in different degrees of subtle.
Last of this board I think. This is the other end – you can see how flaky the wood is on the tips. I had a few chunks blow out in the planer and they just peeled right off. The good news is it adds character for what I’m doing.
Smells amazing, but not like cherry.
I lied. Last picture of this board. You can see the figure I was talking about way better.
And after I coated that with some wax – holy moly. Really brought out the grain :-) You’ll have to wait on that one though, because the wax was just a test to see if I liked how it looked. It’s not done, or even painted, yet.
This is oak (right? haha) but I don’t know anything beyond that. Can you tell what kind of oak it is by the appearance alone? It smelled REALLY intense – not punky at all but very campfire.
This is a different board entirely. To be honest I’m not quite sure where this piece came from, lol. Despite looking kind of pale, it’s actually just as dark – if not slightly darker – than the first board of which I showed you many photos. Very reddy. This is also spalted, yes? Any idea what it is? It’s NOT maple, I’m quite certain. I’ve never seen maple turn golden-red with shellac and it smelled fruity.
And lastly…
Thought this was maple. Did not pay attention to the smell when I was working with it because, as you can see, they are not clocks so the cutting time was short. (The pocketing took 15-20 minutes so it smelled up the whole shop, good or bad)
Same board, different piece. You acn see the rough edges on the top, of this one.
What caught me offguard with this one is that while by appearance I would just write it off as maple, I painted one of the pieces from this board tonight. It felt FAR different than the maple I am used to. (It’s the most common wood I work in) Usually maple is very fun to paint – it burnishes easily so the paint kind of glides over it and slowly soaks in. This is super absorbent, just soaking up the paint and actually drying out my brush. Worse than painting poplar! It’s also extremely dense (so not poplar, right? aside from not really looking like it either.) The bright side I guess is that the piece was dry by the time I was done painting.. haha. If it is maple, it’s a different kind than I usually work in – ideas?
I’d appreciate any suggestions.
And as long as I’m making a blog post, here’s one for the humour bin for you all since you seemed to like that other example of me using my CNC sheet router for overkill.
I used it to rabbet my box edges. Did not finish – was having some mathematical difficulties – but I got the basics done. Let’s file this one under “girl needs a router table”.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
7 comments so far
View nailbanger2's profile
nailbanger2
1041 posts in 3196 days
#1 posted 06-22-2010 04:20 AM
Here’s one for that file, Lis. You may have missed it. I don’t know how much room your new shop will have, but I don’t have a lot, and it looks simple enough that I think I may be able to build it.
http://www.finewoodworking.com/ToolGuide/ToolGuideArticle.aspx?id=28007
-- Wish I were Norm's Nephew
View tyskkvinna's profile
tyskkvinna
1310 posts in 3038 days
#2 posted 06-22-2010 04:26 AM
Thanks!!
While we’re on the subject of cherry- why did the two pieces smell SO dramatically different?
Also I’m glad to hear those lines are just a part of cherry being cherry. I’ve been trying to avoid spalting – don’t want to breathe it.
Ooh hey. That little router table looks great – and also within my skillset. Once I have the shop up and running again space won’t be a problem but I’d like to be able to do some stuff in my garage – this looks perfect for that.
View Ger21's profile
Ger21
1075 posts in 3183 days
#3 posted 06-22-2010 05:10 AM
Cherry, quartersawn red oak, and cherry again. The giveaway on the clock face is the pitch near the #1. That’ll tell you it’s cherry every time.
Oh, and the reason for the chunks coning off in the planer is from the grain changing direction at the end. Rather severely, I might add.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
Ger21
#4 posted 06-22-2010 05:42 AM
I can’t see it clearly enough, but the color looks like red oak to me.
tyskkvinna
#5 posted 06-22-2010 02:22 PM
I did not know what part of the wood was important to take a photo of for the oak- I’ll some good close-ups today! :) I’m very curious, for no purpose other than being curious.
I have to admit I’m not totally in love with cherry, after this. I thought I’d like it more.
View chewbuddy13's profile
chewbuddy13
150 posts in 3338 days
#6 posted 06-22-2010 04:35 PM
I’ve had a similar relationship with Cherry, I was eyeing her from across the shop. We started talking, she was very boring, then a lovely walnut caught my eye. We have had a hot and heavy relationship ever since (don’t tell her but I’ve been seeing some ambrosia maple on the side *high five
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3089 days
#7 posted 06-22-2010 05:44 PM
Well you learn something new every day. I have.
