How I do inlays
Blog entry by tyskkvinna posted 1098 days ago 1000 reads 2 times favorited 10 comments Add to Favorites Watch
I had a lot of response on this subject, and finally got around to doing a blog discussing the entire process.
So this is the machine that I use. It is a Haas SR-100 sheet router. This could be done with any CNC router/mill, really, this is just what I have.
This is the tooling that I use – V-Cutters from Hersaf. I did a lot of research into v-cutters, because I do a lot of engraving. I was told by several people that Hersaf is the best. I have a set of them and I have to agree – they are absolutely amazing. I’m told by Hersaf that they’ll even cut aluminum but I admit I’m scared! :) You don’t need a CNC machine to use these – they’re intended for cabinetry.
Ok so I cut the design into two pieces of wood. (Sorry I didn’T get photos of the cutting part; I was busy doing other things while it was cutting) The left is walnut, the right is maple. On the walnut I cut the design with a 90-degree cutter, basically as normal. On the maple, I cut the design (reversed) on the outside.
Close-up of the walnut.
Close-up of the maple.
You can see that they line up pretty well.
And then sit on top of each other perfectly.
I fill the walnut piece with glue. (Good ol’ Titebond III) As you can see, I am extremely liberal with the quantity of glue. It’s necessary. I’ve had pieces fail pretty hardcore because I missed a glue spot. Also rather than using a paintbrush I use a stick… years ago I was at a dollar store or something similar and they had bags of 1000 pairs of disposable chopsticks. Somehow I have more than a dozen of these bags, use them all the time,and it will still take me another ten years before I run out. But they’re perfect…
I don’t put any glue on the maple piece – it’s too hard to judge where all the glue is. I suppose I could use some kind of spray method, but this works, is pretty quick, not messy.
Clamp it all together. I try as much as possible to even out the pressure, but I also only put pressure on where the two pieces join. If I clamp on the edges of this design, it will pull the centre out and it won’t work. For this purpose, among others, I prefer to do designs that are fairly even distributed.
After it dried, I cut off the excess maple. (There was a lot – usually I try to pick a thin piece of wood, but eh.
There you go.
This particular one is kind of wonky… thanks to some weird parts on the initial design. When I do a normal v-carving of it, it looks very symmetrical, but it’s not at all. You can see that strongly here.
This is what it looks like when I do a normal carving of it…
also, I kind of messed up by removing too much material. But at that point -what can you do? Nothing.
It’s okay, somebody will love it I’m sure. :)
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
10 comments so far
View dustbunny's profile
dustbunny
1148 posts in 1468 days
#1 posted 1098 days ago
Wow Lis,
This is really cool.
I guess CNC can do some wonderful things.
Would have never thought of this myself….
Nice work : )
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
View jockmike2's profile
10636 posts in 2419 days
#2 posted 1098 days ago
Cool, very cool.
View CedarFreakCarl's profile
CedarFreakCarl
595 posts in 2226 days
#3 posted 1098 days ago
Simply ingenious! My hats off to your creativity. Thanks!
-- Carl Rast, Pelion, SC
View darryl's profile
darryl
1785 posts in 2499 days
#4 posted 1098 days ago
that’s pretty neat!
View Dennisgrosen's profile
Dennisgrosen
10854 posts in 1288 days
#5 posted 1098 days ago
clever idea I can see why a cnc can have good use to this kind of inlay
where there is so many small pieces
thank“s for sharing
Dennis
View lew's profile
lew
8989 posts in 1928 days
#6 posted 1098 days ago
Uber Cool, Lis!!
That is one neat CNC machine.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
87380 posts in 1750 days
#7 posted 1098 days ago
A great job impressive results
TopamaxSurvivor
13194 posts in 1848 days
#8 posted 1098 days ago
WOW!! That almost seems like cheating;-)) too easy.
View Brad_Nailor's profile
Brad_Nailor
2450 posts in 2130 days
#9 posted 1098 days ago
View Bob Simmons's profile
Bob Simmons
505 posts in 1187 days
#10 posted 1079 days ago
Hey…I love it! Very creative.
-- Bob Simmons, Las Vegas, NV, http://TheApprenticeandTheJourneyman.com
