A Big Thanks
Forum topic by davidpettinger posted 09-02-2009 03:46 PM 741 views 0 times favorited 2 replies Add to Favorites Watch
View davidpettinger's profile
davidpettinger
661 posts in 3102 days
09-02-2009 03:46 PM
I just wanted to take the opportunity to thank all of you helped me with my problem. Although, I ended up with an entirely different solution to the problem than I had initially intended. I was looking for blades to fit my Jointer, I had help from guys like marcb, MAX, brianipa, and a couple of others. The solution to the problem was not finding knives, it was having the slots in the head widened by 3/64th’s of an inch to make it a true 1/4 inch wide. This in noway compromises the integrity of the head. What it does make possible is the use of standard 1/8th inch knives. Thanks again to all of you, LJ’s rule.
-- Methods are many,Principles are few.Methods change often,Principles never do.
2 replies so far
116900 posts in 3479 days
#1 posted 09-02-2009 06:15 PM
good solution
View Don Newton's profile
Don Newton
714 posts in 3520 days
#2 posted 09-02-2009 06:37 PM
Don’t raise the bridge, lower the river!
-- Don, Pittsburgh
