Items For Sale
Forum topic by kdc68 posted 05-26-2015 12:41 PM 1622 views 0 times favorited 5 replies Add to Favorites Watch
View kdc68's profile
kdc68
2649 posts in 2243 days
05-26-2015 12:41 PM
Topic tags/keywords: for sale resource
Please view the items for sale. If interested in anything then send me a PM. I accept Paypal.
v
v
THIS ITEM IS SOLD
Craftsman Miter Gage With Hold Down Clamp
This miter gage is from an old 113.XXX table saw I used to own.
The miter bar is a standard 3/8” x 3/4”
For it’s age is in good condition.
Comes with Hold Down Clamp.
Hold Down Clamp is complete with all hardware, instruction manual, and box.
Asking $25.00 plus shipping.
v
v
THIS ITEM IS SOLD
25 Piece Drum Sanding Kit With 15 Piece Refills
This kit was barely used with only one packet of 80 grit sleeves used and still have sanding life. The other packets are unopened.
The kit includes
1 – 1/2” x 1/2” Sanding Drum – (1/8” Shank)
1 – 3/4” x 1” Sanding Drum – (1/4” Shank)
1 – 1” x 1” Sanding Drum – (1/4” Shank)
1 -. 1-1/2” x 1-1/2” Sanding Drum – (1/4” Shank)
1 – 1/2”x 2-1/2” Sanding Drum – (1/4” Shank)
20 sanding sleeves: - 10 (2ea. for each drum size 80 grit) - 10 (2ea. for each drum size 120 grit)
Plastic Storage Case
15 Piece Sanding Sleeve Refill
Unopened and unused. Includes: 1 ea. of 80x, 120x & 150x for each drum size
Asking $20.00 plus shipping
v
v
Dewalt DNP612 Plunge Base
This plunge base is for the DWP611 Compact Router.
I have two of these bases and this one has never been used and is in new like condition.
Asking $50.00 plus shipping
v
v
THIS ITEM IS SOLD
Rockler Inter-Loc Inserts
These inserts are used for the Rockler One Router Table Plate with 3-1/4” Insert Opening. These will fit the router table plates I have for sale.
Pictured on left is for the standard 1-3/8” Guide Bushing. It is used but in good condition. Comes with mounting screws and original packaging.
Pictured in middle has a 2-1/2” opening for larger bits. It is used but in good condition. Comes with mounting screws and original packaging.
Pictured on right is a blank. It can be drilled out to a custom size. It is never been used. New in package.
Asking $15.00 for all three
Asking $10.00 for all three if purchased with one of the router table plates I have for sale.
v
v
THIS ITEM IS SOLD
Rockler Router Table Plate (Standard Blank)
This plate has never been used. Unopened new in box.
The plate dimensions are 1/4” x 8-1/4” x 11-3/4” and is CNC milled anodized aluminum.
This is a blank, requiring you to drill your own holes to mount your brand of router.
This plate uses the 3-1/4” standard inserts.
This unopened box includes one 3-1/4” standard insert with an 1-1/2” opening, one starting pin, and two mounting screws.
If you own a Rockler table top, then the supplied hardware will be needed to complete install.
If you do not own a Rockler table top, then I will supply similar hardware that would come with Rockler tops.
The hardware I will provide are 2- T nuts to be used to secure the plate to the table top and 8 – confirmat screws to be used to level the plate flush with the table top.
Asking $45.00 (plus shipping) for plate and hardware.
Asking $55.00 (plus shipping) for a combined purchase of this plate and hardware, and the three inserts I have for sale
v
v
Rockler Router Table Plate (Standard Group B)
This plate is used but in good condition. Minor scratches on surface but otherwise good condition.
This is a Group B plate that has predrilled mounting holes for:
>Dewalt DW621/621K
>Craftsman Standard
>Freud FT 1700E
>Freud 1702 VCEK
Everything that came new is supplied which includes one 3-1/4” standard insert with an 1-1/2” opening, one starting pin, and two mounting screws.
Asking $30.00 (plus shipping) for plate and hardware.
-- Measure "at least" twice and cut once
5 replies so far
kdc68
#1 posted 05-26-2015 08:56 PM
Drum Sander Kit is SOLD…...
kdc68
#2 posted 05-27-2015 09:19 PM
Craftsman miter gage and hold down clamp reduced to $35 plus shipping
kdc68
#3 posted 05-29-2015 11:06 PM
The Craftsman Miter Gage, Dewalt plunge base, and Rockler router table plate (standard group B) are still available
kdc68
#4 posted 06-01-2015 10:54 PM
Price reduction. See listings and pictures above
kdc68
#5 posted 06-20-2015 06:53 PM
Craftsman Miter Gage is sold
Dewalt 611 Plunge Router Base is still for sale for $50.00 plus shipping
Rockler Router Table Plate (Standard Group B) is still for sale for $30.00 plus shipping
See details above
