Oscillating tools
Forum topic by thumbs posted 87 days ago 296 views 1 time favorited 6 replies Add to Favorites Watch
View thumbs's profile
thumbs
16 posts in 973 days
87 days ago
Oscillating tool
Need to remove large amt of 1/8” inch grout. Have been reading about the various brands of tools—Dremel-through Fein. Large price difference, but would rather pay and get something that would do job than save some $ andnot. Was surprised that some aren’t designed to cut metal. Would appreciate any advice. The grout is the priority right now, but would want it for the multi-use later. Also if anybody has another suggestion it would be most welcome
-- Mitakuya Oyasin
17042 posts in 475 days
87 days ago
I have a Fein Multi master that will do the job and many others now they make copies as low as $39.99 at HF. If you like this tool you might try the HF tool first and then up grade to the $339 Fein If you like the way the HF works.
View papadan's profile
papadan
478 posts in 267 days
87 days ago
I second the Fein! The copies just can’t match it.
-- Dan-- Info for all @ http://www.hoistman.com
View ahock's profile
ahock
72 posts in 222 days
87 days ago
I third the MultiMaster (the newer one with the star on the head to lock the blades down)
-- Finding satisfaction in creation
View Blondewood's profile
Blondewood
100 posts in 243 days
87 days ago
I have the dremel multi-max. It’s a good solid tool. Only used it for sanding thus far. I know I would like the Fein’s range of attachments better. I could get the rubber sanding shapes. If all you need to do is remove grout, the Dremel hand held used to have an attachment for that. Also, I think the tip of getting the HF cheapie first is good. I’ve done that with many tools and it’s worked for me. If you do a LOT of ww and home repair then go for the Fein.
Vicki
View Kent Shepherd's profile
Kent Shepherd
840 posts in 185 days
87 days ago
Any heavy use—Go Fein, no doubt. Home use only, maybe some of the others, but I personaly would still buy Fein.
Well actually I did. It’s great!
thumbs
87 days ago
Does anybody have any experience w/the Rockwell Sonic Crafter? If so how would you compare and rate it?
Thumbs
-- Mitakuya Oyasin
