How do I prevent sanding sleeve from sticking to rubber drum?
Forum topic by WoodNSawdust posted 05-25-2015 06:58 PM 931 views 0 times favorited 7 replies Add to Favorites Watch
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1414 days
05-25-2015 06:58 PM
Topic tags/keywords: sanding drum sanding question
Tomorrow I will need to use the oscillating spindle sander to sand a curve smooth. After I insert the sanding sleeve / drum onto the rubber drum I have problems getting it off. Before another fight I thought I would ask if there was anything I could ahead of time to make removing the sleeve easier?
Thanks in Advance
7 replies so far
5236 posts in 2730 days
#1 posted 05-25-2015 07:28 PM
I’ve read (but not tried) that putting a little talcum powder on the drum first helps with this. I’ve not had one stick just after a short use, but have left a drum tightened for a while…then it becomes a headache. There are other after the act remedies. Putting the drum in the freezer (usually overnight) might help, or you could just put a hose clamp around the thing and squeeze it back enough to get the sleeve off.
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#2 posted 05-26-2015 12:09 AM
Talcum powder works as a preventive. Banging on the outside of the sleeve with a rubber mallet will loosen a stuck on one.
View BurlyBob's profile
BurlyBob
6031 posts in 2503 days
#3 posted 05-26-2015 12:18 AM
Thanks Gfadvm, I got to try that tomorrow.
gfadvm
#4 posted 05-26-2015 12:27 AM
You are quite welcome BurlyBob.
View lew's profile
lew
12500 posts in 3993 days
#5 posted 05-26-2015 01:41 AM
I had one stuck once. Put it in the freezer for a while. I came off.
I’ve gotten in the habit of backing off the nut that squeezes the rubber as soon as I’m finished. That’s helped a lot, too.
View Planeman40's profile
Planeman40
1330 posts in 2998 days
#6 posted 05-26-2015 04:25 PM
On smaller drum sanders I have used the compression of the rubber drum method, usually by rolling it between two small boards while compressing the rubber. Works well. Getting a new sanding sleeve on is another problem. I wet the rubber drum, usually by spiting on it (eeew!) and wiping it all around the rubber drum. Sliding the sleeve on is much easier.
Planeman
View Betsy's profile
Betsy
3392 posts in 4133 days
#7 posted 05-26-2015 05:40 PM
I’m in the talcum powder club. Works great and leaves a nice aroma to boot!
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
