Cross dowel nuts
Forum topic by botanist posted 88 days ago 470 views 0 times favorited 9 replies Add to Favorites Watch
View botanist's profile
botanist
44 posts in 437 days
88 days ago
I’m trying to find cross dowel nuts that will accept a 1/2 inch threaded rod. I know that Lee Valley and a number of other sites sell bench bolts that come with a the nuts included, but I haven’t been able to find anywhere that sells dowel nuts that large separately. Does anyone out there have any good sources for stuff like that?
View Kindlingmaker's profile
Kindlingmaker
1477 posts in 425 days
88 days ago
Maybe? http://www.profhdwr.com/asstment.htm
botanist
87 days ago
I’ve tried that website, but I haven’t had much luck. I’m tempted to buy round bar stock and make them myself, but if I can find another source, I would. Everything that I’ve found so far is for basic furniture and is too small for what I need. I need something with dimensions of at least 25 mm x 25 mm that can accommodate a 1/2 inch bolt with 13 threads/inch.
View DaveR's profile
DaveR
1527 posts in 619 days
87 days ago
Did you check with McMaster-Carr or Grainger or Fastenal?
-- Until you spread your wings, you'll have no idea how far you can walk.
botanist
87 days ago
All three of those places were a bust. The only one of those three that carried any cross dowel nuts was McMaster-Carr but they were much too small for my needs.
View UnionLabel's profile
UnionLabel
149 posts in 99 days
87 days ago
Try alibaba.com. type in barrel nuts and take a look. Quite a selection and if anybody has it they do.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
botanist
87 days ago
I tried alibaba.com but I still didn’t have any luck. I’m probably just going to have to make my own. Thanks for the help everyone.
DaveR
87 days ago
Out of curiosity, do you have to have cross dowels? Could you use a regular nut or a square nut plate dropped into a mortise?
17044 posts in 475 days
87 days ago
How about
http://www.louisandcompany.com/storefront/
or
http://woodworker.com/search.asp?CTLFIND=080.
botanist
87 days ago
I don’t have to have cross dowels but I thought it might make my assembly easier. I’m building my first workbench and I’m trying to find a way to attach the dog hole strip to the top. I used the bench bolts from Highland Woodworking to attach the stretchers to the legs and I thought using them on the top would work.
