Calling All Luthiers
Forum topic by CharlieM1958 posted 09-01-2009 04:09 PM 1805 views 1 time favorited 27 replies Add to Favorites Watch
16281 posts in 4460 days
09-01-2009 04:09 PM
My 35-year-old Alvarez guitar is in need of some fret work. The last couple of frets closest to the nut have worn down so far that the darn thing is almost impossible to play without a capo. I’ve done a little surfing on the subject, and I’ve ordered some fret wire from Stewart-MacDonald (a couple different sizes so I can try to match what was there).
Are there any words of wisdom, must-dos, must-don’ts, learned-the-hard-ways, or other advice from my fellow jocks here?
27 replies so far
View mmh's profile
mmh
3677 posts in 3964 days
#1 posted 09-01-2009 04:44 PM
Hey Charlie,
My neighbor is a luthier and I’ll try to get him to join the forum and post. He just stopped by to acquire some ebony to fix a 1928 mandolin. Meanwhile, don’t fret.
#2 posted 09-01-2009 04:51 PM
Hey, that’s a pun bad enough for ME to use. Thanks. :-)
View SteveE's profile
SteveE
56 posts in 3751 days
#3 posted 09-01-2009 05:15 PM
Ohh! This thread is pertinent to my interests. I have a guitar that is hard to fret and I suspect that it is because either fret wires are worn or it is just not that great of a guitar. I too wounder how to decide what the size fret wire is correct.
-- Measure twice, cut once, bang into place
View scott83's profile
scott83
14 posts in 3431 days
#4 posted 09-01-2009 05:29 PM
I build and repair guitars. Call me to discuss respective problems, as that’s easier for me than emailing a hundred times to troubleshoot with you.
Thanks,
Scott
678.215.3108
-- Scott
#5 posted 09-01-2009 05:45 PM
Thanks, Scott. I’ll give you a call before I dive in.
View Dan'um Style's profile
Dan'um Style
14179 posts in 4224 days
#6 posted 09-01-2009 05:46 PM
Hey Charlie
My best advice is … everything in moderation !
#7 posted 09-01-2009 05:56 PM
Oh thanks, Dan. Next, I expect Odie will chime in with a goofy photo. :-)
View woodworm's profile
woodworm
14470 posts in 3832 days
#8 posted 09-01-2009 07:05 PM
It’s so unfortunate, I can play guitar but cannot repair it.
In fact the strings tuning also is always done by my friend (my mentor)...LOL
-- masrol, kuala lumpur, MY.
scott83
#9 posted 09-01-2009 07:26 PM
Btw, my website is www.smorganmusic.com. Let me know what you think.
Thanks,
Scott
-- Scott
scott83
#10 posted 09-01-2009 07:31 PM
Hi Woodworm,
Repairing guitars is pretty easy. You only need a 16 ounce hammer. I haven’t picked up a framing hammer in years, but I still have one. Good luck on your journey to understanding wood and tools, and having a shop. My shop is 5’ by 10’. Could definitely use a little more space.
Regards,
Scott
-- Scott
scott83
#11 posted 09-01-2009 07:33 PM
Hey SteveE,
Your problem could be set up and adjustment rather than fret related. Hard to say without looking at it. Can you post pictures?
Later,
Scott
-- Scott
Craftsman on the lake
2848 posts in 3679 days
#12 posted 09-01-2009 08:34 PM
Those frets are the easiest to replace. you’ll need to make a block about 4×4” to put under the neck. make a cup in the top to accept the neck and if possible line it with felt or at least place a folded washcloth in it. Use some tape, elecrical works good to tape down the wood on each side of the fret. Stretch the tape if using elecrical and it will act just like a clamp to hold down the wood to avoid any chipout at the fret edges.
Buy some front tine pliers. they’re used for clipping wires. They have a blade that is perpendicular to the handles, on the front of the pliers. Put them on a grinder so that they make a flat surface when held on the fretboard but till have a sharp edge to grab the fret. Pull the fret from the middle then the ends with a back and forth rocking motion.
When you replace the fret be sure your block is directly under the fret and hammer it on with a metal head hammer. tap it in. clip the ends of the frets off.
You’ll need a large flat millers file to file them the same level as the others. Then carefully round them with a small three cornered file and file the ends flush and tapered on the ends. Buff them with steel wool and you’re done.
View reggiek's profile
reggiek
2240 posts in 3512 days
#13 posted 09-01-2009 08:53 PM
I don’t do anything with guitars or instruments myself, but I know that one of the owners of Grizzly is a guitar afficianado…I’ve seen kits and various supplies on their web page and in their catalog…...that said though it appears there are quite a few folks here that have you covered….just wanted to add my good luck in here.
#14 posted 09-01-2009 09:10 PM
Craftsman, thanks for the good how-to. I think I have all the tools already, so it’s just a matter of technique. Good tip about taping down the surrounding wood to avoid chip-out. That’s exactly the kind of advice I was looking for.
#15 posted 09-02-2009 12:28 AM
You’re welcome. I may be sweating the desks and drawers and such but I’ve made a few dozen guitars in my day. and repaired upteen of them over the years.
Don’t forget to leave the tape on if you can till you get the new frets in. If there is any loose wood the tape will rip it off. But if you put the new frets on then the fret will hold the wood on for the tape to be removed.
Also, the tang.. small hooks on the fret… sometimes are for new fret slots. Old fretslots may be too wide. They sell wide tang frets but another technique that works good with an ebony fretboard because it’s black with no visible grain, is to mix some ebony dust with epoxy, then fill the fret slot, file and sand, and recut the fretslot after. Please don’t try to glue the fret in. It’s a nasty trick to play on the next guitar repair person. The fret is removed and takes half the fretboard with it.
