« back to LumberJocks.com Site Feedback forum
| Forum topic by woodisit | posted 89 days ago | 318 views | 0 times favorited | 6 replies | ![]() |
89 days ago |
89 days ago |
I’ve used salad bowl finish on end grain cutting boards, but not sure about a kitchen island. The salad bowl finish will shine up like poly, except it is food safe. Takes multiple coats with sanding in between. Just my 2. -- Rick |
89 days ago |
Another vote for Salad Bowl finish here. -- Custom Daguerreotypes from your images and more: www.shinyphotos.com |
89 days ago |
Look at the “WoodWhisperer’s” web site. He has a good presentation. -- Never board, always knotty, lots of growth rings |
89 days ago |
Another vote for salad bowl finish the Wood Whisperer way. I have had great sucesss with it on end grain cutting boards. -- Derrek L. |
89 days ago |
n -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
89 days ago |
Salad bow finish produces a surface coat that will wear and cut off with use. I would never use it on a work surface like a butcher block. Mineral oil or processed Walnut oil (my preference) are much better and should be renewed every 3 to 6 months depending on use the block gets. Mineral oil never really dries out and some people also dissolve some paraffin in it. You need to heat it to dissolve the paraffin….use caution doing this, you don’t want a fire. Processed walnut oil (it is heat treated) actually cures/dries in the wood providing both a seal and helping harden the wood fiber…..it does not add any color. One small draw back to walnut oil might occur if someone using it is “highly” allergic to walnuts I guess they could have a reaction but I doubt it because of the heat treating process. The least expensive mineral oil is often found in the department store pharmacy; baby oil is mineral oil, just get the unscented type. -- Les B, Oregon |
| Forum | Topics |
Woodworking Skill Share
2931 |
3963 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
524 |
