Forum topic by recycle1943 | posted 05-23-2015 07:19 PM | 1487 views | 0 times favorited | 10 replies | ![]() |
I have a Sears 149.213330 Radial Drill Press – nothing wrong with it BUT I have a tendancy to attempt to make things a little easier on ME and presently that endeavor is to put a keyless chuck on the dp. -- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them |
10 replies so far
#1 posted 05-23-2015 07:28 PM |
Here is the manual for a 149.213340 which should basically be the same: The chuck is on a taper, so you just need to knock it off. I would not put a keyless chuck on though… there is a reason most don’t come with one – you can’t tighten them enough and will wind up spinning bits, particularly large ones and when doing tough material like very hard wood and metal. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 05-23-2015 07:34 PM |
Dick, check this out on YouTube – It give some suggestions on how to get more info on the Craftsman DP chuck. Hope it helps. BTW, I’ve used the Red Cedar, but I haven’t been into the shop for the last 10 days or so, been fighting a lower leg infection. On the mend now, hopefully I can get back in next week. https://www.youtube.com/watch?v=NjLQUP19IyY -- Bill - "Suit yourself and let the rest be pleased." http://www.cajunpen.com/ |
#3 posted 05-23-2015 07:50 PM |
Thanks Brad but that manual doesn’t show the clooarand there is no slot in the quill -- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them |
#4 posted 05-23-2015 08:00 PM |
Parts listing shows the chuck, and it looks like a standard taper fit… Don’t see any thing else that would secure it to the taper shaft in the exploded parts diagram… maybe yours has been modified from original if it’s different than what is shown. Cheers, PS: The parts diagram in the manual I linked to looks almost identical to the one on the sears site for your model number, with the only exception I see being the table (one is round, other isn’t). It does show a collar, but doesn’t indicate where it goes and is not shown as part of the full quill assembly (#37 in the diagram). Based on where you say it is, it is most likely just a cover to protect the lower quill bearing. A picture would help :) -- Brad in FL - In Dog I trust... everything else is questionable |
#5 posted 05-23-2015 08:49 PM |
Dick, I too have a Craftsman dp, not like your radial, but similar in construction. There is no quill to remove, the chuck is a press fit onto a spindle, tapped on by mallet. No instructions as to removel, all part of a lesser expensive design & build. -- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln |
#6 posted 05-23-2015 08:57 PM |
I did a quick search for that chuck number (RJ3-16L) and it indeed has a Jacobs taper #3 mount, so it is just an interference fit and should pop off with some light taps, or you might need to get a couple wedges if it’s really stubborn. There are other methods (such as using a homemade slide puller) that a quick google search will turn up for you as well. It’s also used on quite a few other model presses (Rikon, Jet, etc…), but I doubt any of them show how to remove it either – just how to install it. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#7 posted 05-23-2015 08:58 PM |
Dick, I found your answer, see this video: https://youtu.be/gWwmgC_TkBQ -- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln |
#8 posted 05-23-2015 09:02 PM |
OK guys – it’s off ( I found my stupid switch and turned it off, only tempory of course ) Thanks guys -- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them |
#9 posted 05-23-2015 09:05 PM |
YAHOO !! that is going to be a BIG help. Thanks -- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them |
#10 posted 05-30-2015 12:53 PM |
Very interesting topic. Sorry I don’‘t have a clue. A lot of good answers and links above. Thnx all. -- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed. Kentuk55@yahoo.com |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2109 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6697 |
28075 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
