| Forum topic by PatP | posted 89 days ago | 301 views | 0 times favorited | 9 replies | ![]() |
89 days ago |
89 days ago |
Well, I own two and I lead our club’s Shopsmith SIG, so I guess I can talk a little about them. I don’t own a table saw other than the Shopsmith and I use it for that. That said, it is not the best table saw in the world. The table is not large and it moves up and down, so it is hard to build an outfeed table for it. Even with the 1 1/8 hp motor, it still bogs down on heavy cutting. The fence on the model 500 and 510 (the two I own) is alright, but you have to be careful in locking it down that it is parallel to the blade. I measure front and back a couple of times each time I set it. As a drill press and sander, it is great. I actually use the horizontal boring quite a bit for dowel joints. I like the lathe a lot, although I wish it would go slightly slower to turn bowls. But it is a fine spindle lathe. All this sounds like faint praise. So why do I own two of them? Because you can’t get a more versatile set of machines in that small a space anywhere else. I also have the router attachment, band saw and strip sander. Without a speed increaser, you should skip the router attachment. The band saw is very good and so is the strip sander. It gets a little frustrating to switch between operations, but it all fits in my relatively small shop. And it is a quality product. I will admit that I bought both of mine used, but if you watch Craig’s List or eBay, you can get some pretty good deals. Plus I (and the others in our SIG) have a terrific time thinking up new uses and accessories for the Shopsmith. We’ve built sanding dust collection attachments, under-table storage units, lighting mounts that hang on the way tubes, and about a dozen other ideas. One of the guys takes used Shopsmiths, cuts the tubes down, and make them into minis for dedicated machines. One guy has used the Shopsmith to cut and shape granite pieces as part of a lamp. It is just a great machine and there is no end to what it can do – in a very limited space. |
89 days ago |
ddockstader, WOW! Glad I asked here first. Thanks so much for your very informative post. I don’t have space issues since I moved to Florida, I have a 100’x80’x28’ steel building that I built to work on hot rods but got involved in this woodworking thing also. I do own most of the tools that the ShopSmith offers except a lathe. I figured for $500 I might be able to use some of the attachments for dedicated machines?? Guess it wouldn’t hurt to go and have a look at this one. Thanks again! -- Pat>>> A Man Don't Learn a Lesson Unless It Costs Him Blood or Money!!!!! |
88 days ago |
100’ x 80’ – I’ll trade you one of my Shopsmiths for that building! We just need to move it to Illinois. |
88 days ago |
My shop is 16×20 which is why I own a Shopsmith and have for 25+ years. I own the 520 with larger 1 1/4 HP motor, I would not recommend the smaller motor, and with thin blades I have yet to find something I can’t cut well. The 520 has more table surface and I have infeed and outfeed tables as well as enough other tables to end up with a 25ft square plane all around the saw for cutting large sheet goods (but only outside). You can check out the shopsmith forum for more information, all the questions you will have have already been answered. -- Paul, Beaverton OR, www.TravelbyPaul.com |
88 days ago |
Hey PatP, Weakness: Low lathe can cause back aches if you are tall, and the high/tilting saw table takes some getting use to. Scott -- http://shopsmith-tool-hunter.blogspot.com http://gilliom-gil-bilt-tool-hunter.blogspot.com |
86 days ago |
I have a 1993 mark V 500 with the bandsaw attachment. Here in minnesota I paid $400, I found it on craigs list. It was in clean usable condition. I also recomend the shopsmith forums, There is a ton of info there. -- JohnnyP - Lindstrom, Minnesota |
27 days ago |
I just inherited mine from my father. However I have a lot of experience with it. I have to say you need to manage your expectations when buying and using a Shopsmith. If you need a high production shop full of tools and need to move from machine to machine to accomplish a lot of produciton work, then maybe this may not be the best choice. However in the case of most owners, two issues ring true. First is storage space. I doubt there is anything else on the market that can top it. Second, if you are cutting large sheets of plywood all the time, you need to think about an outfeed system. There is a product called Sawtrain that has a system specifically made for the shopsmith. Most owners of the shopsmith are NOT production cabinet shops. We use it for fun and enjoyment. There is little it cannot do, but there are usually work arounds when you run into trouble, and there are a lot of people out there that are willing ot offer assistance. |
27 days ago |
Pat, Don’t want to sound negative, but just looking at it from the other side. Biggest plus is space…...Sounds like that’s not a problem for you with the size of your shop. The second is they offer a lot of tools for the budget and that’s hard to beat…....but then again, I see you work on Hot Rods, doesn’t sound like that is your biggest draw back either. LOL. -- John @ Myrtle Beach |
27 days ago |
Huff, I think with a large shop where you have different stations set up, it may allow you to work more efficiently. I can certainly attest to having to do a great deal more planning with my projects. I try to do all my cutting, then move to other tasks as needed. I find that the majority of my work is with the table saw and using the dado blades. I don’t usually use the lathe, or the horizontal boring bar, and I have a bench mounted drill press that covers the majority of what I need it for. But I had those before I got the shopsmith, so if I didn’t have one, then it certainly would save me some money there. |
| Forum | Topics |
Woodworking Skill Share
2920 |
3945 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
