Adjusting miter gauges
Forum topic by Praki posted 91 days ago 352 views 0 times favorited 19 replies Add to Favorites Watch
View Praki's profile
Praki
139 posts in 896 days
91 days ago
Topic tags/keywords: question tablesaw
I just found out that the stock miter gauge which came with my Delta 36-980 table saw is not aligned perfectly to 90 degrees. I thought there might be some way to adjust it but nothing obvious. The manual simply states that, the gauge has positive stops at 90, 45, 30 and 60 degrees. Can this be fixed or do I junk it and spring for an adjustable one? If so, recommendations please!
Thanks
-- Praki, Aspiring Woodworker
View pcott's profile
pcott
8 posts in 144 days
91 days ago
I don’t mean to sound facetious, but I fixed my delta mitre gauge by replacing it with an Osbourne eb3.
View TomHintz's profile
TomHintz
83 posts in 297 days
91 days ago
I am not familiar with that particular miter gauge but most have a screw (or some type of adjustable fastener) on/at the stop that can be used to fine-tune the setting. If the gauge does not have something like that, I would opt to toss it and get a better one. If you need to get one, see the link below for my review of the Incra 1000SE which is very popular and currently is my only miter gauge on my table saws.
Incra Review
-- Tom Hintz, www.newwoodworker.com
View 45acpbuilder's profile
45acpbuilder
49 posts in 111 days
91 days ago
Praki, go to “tablesawalignment.com” and read how he does it. He has a dial indicator holder for sale but you can use the same technique with a home made holder and align everything on your table saw to .oo1! I have two miter guages – one set to 90 deg that never gets moved and another for angles. I just looked up your saw and it’s advertised as having adjustable stops on the miter guage. If it doesn’t have adjustments to fit the miter bar to the table slot, I’d get a different one that does. Look at Grizzly’s “cast iron” miter guage and you’ll see how everyone does this.
-- M1911BLDR
View niki's profile
niki
429 posts in 979 days
90 days ago
You can adjust it to 90° and 45° with this “Lo-Tech” method…
Of course if you have the digital angle guage like the “Wixey”, you could set it to any angle…
niki
View jerryz's profile
jerryz
109 posts in 178 days
90 days ago
I have the manual for this Table Saw and the Miter Gauge that comes with it has a notch and a spring actuated detente. BTW if you do not have the manual you can download it from here:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A18825,36-978%2036-979.pdf
have you checked with a machinist square that the bar that go onto the miter slot is 90 Deg to the fence?
If it is, then the problem is that your miter slot is not parallel to the blade and you will have to adjust it by loosening the 4 screws that fix the Trunions to the table top using a mallet or/and a 2×4 lever to correct the problem, better yet get and install a PALS Contractors Table Saw Alignment System.
Either Rockler or Woodcraft carry them you can see what it is all about here:
http://www.woodcraft.com/Family/2020591/2020591.aspx
Also while at it if you want a better miter fence look at the fine miter gauges offered by Incra they start at around $65.00
Praki
90 days ago
Thanks guys.
pcott – I will take a look at Osborne eb3.
Tom – Incra would be one of the choices if I decide to toss this one.
45acpbuilder – thanks for the pointer. I will take another look and see if I have the right manual.
Niki – thanks for the pictures and the ideas. My miter gauge has notches and detente which makes it impossible to fine tune the angle. I was thinking of attaching a piece of hardwood with a shim at one end.
Jerry – the miter slot is parallel to the saw blade. It’s the miter fence that is not exactly at 90 degrees to the miter bar. Unless I find a way to adjust the stops (which 45acpbuilder said it is), I may have to buy a replacement miter gauge.
View jussdandy's profile
jussdandy
101 posts in 106 days
90 days ago
I still have my stock Delta, it makes a good paper weight, I use a Kreg precission miter fence, I use it on my unisaw and my router table both, not saying it the best but its what I got and it works great.
-- Randy, Fla http://www.kelleyscabinetsupply.com
View mikedddd's profile
mikedddd
61 posts in 129 days
90 days ago
Stock miter gauges tend to be inaccurate in my opinion, even if you get them trued up I’ve found they are easy to knock out of square, not that that is a big deal you just have to keep double checking them while using them. I have a Incra 1000 SE now which I like, I still double check it as I’m using it, but have found it doesn’t move, it is also allot easier to fine tune to an exact angle with the vernier cursor. I haven’t had a chance to you use any of the other aftermarket gauges out there, but I think they would also be easier to adjust and keep adjusted then the one that comes with the most table saws.
-- Mike
View niki's profile
niki
90 days ago
“My miter gauge has notches and detente which makes it impossible to fine tune the angle.”
Well, in this case you can align the Miter gauge Fence to the Slot using big triangle…
For the clarity, I’ll use the plywood home made triangle
Fill with your finger the closer side…
And the far side…
Or, you can make a runner that fits perfectly but extends above the table
And adjust the fence to 90°…
Regards
niki
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 484 days
90 days ago
Hi the half circular strip with the degrees marked on it should be movable hence the two locking nuts on the top of it surely its just a matter of slackening ,then fine tuning this and retightening it.Alistair
View notottoman's profile
notottoman
487 posts in 129 days
90 days ago
Making the obvios look so easy.
Thanks – Niki i’ve just learned something.
-- "Even small steps makes a distance." (Shawn Phillips, musician)
Praki
90 days ago
Niki – thanks. Those triangles look awesome. My plastic triangles look … plasticky in comparison :)
Sctosman – you are right indeed. After I looked at some miter gauges and almost bought the Incra, I decided to take one last look at my miter gauge. I found the screws attaching the plates but I managed to strip them. At least, now I know it is adjustable and the tough task is to remove the stripped out screws and adjust it.
TopamaxSurvivor
3070 posts in 575 days
90 days ago
I was going to buy a spendy Incra, but then I though I have a digital angle gauge, why not just use it? :-))
45acpbuilder
90 days ago
All good ideas, but I still suggest using the method described at tablesawalignment. His method eliminates all possibilities of your squares not being true and “shake, rattle and roll” in the fit between the miter bar and miter slot effecting the final adjustments. If you’re going to spend the time to square things up, why not adjust to the BEST possible level? Machinist squares and dial indicators are available for little money and once you have them, they can verify ALL of your adjustments. I even use them to verify my Wixey, which I found to be .1 degree off. Now that I know that, I can compensate easily.
-- M1911BLDR
View ajosephg's profile
ajosephg
443 posts in 460 days
90 days ago
After fighting miter gauge alignment for years, I finally broke down an bought an Osborne a few months ago.
Problem solved. It was aligned when I got it, and it stays aligned (it is adjustable in the unlikely event it ever needs adjusting). Plus it has many other features.
The bottom line is do you want to cut wood, or spend all your time fighting the machine and its “stuff?”
PS: (I do check alignment ever so often with a TS Aligner Jr. as described at tablesawalignment.)
-- Joe
View BTKS's profile
BTKS
492 posts in 363 days
89 days ago
If your going to toss the old gauge at least save the bar for future jigs, etc. The handle might even be handy one something else. Just a thought from someone who’s been alleged to be tight with a penny. Best of luck, BTKS
pcott
8 posts in 144 days
89 days ago
Hey, just keep it for a bandsaw or a router table.
View pirate's profile
pirate
3 posts in 85 days
85 days ago
I just got an Incra 1000SE,in a trade, and all I can say is WOW. set angles to 1/10 of a degree if you need to.
The adjustment on the miter bar is very nice to get play down to zero. This is the big problem with most stock gauges.
I would invest in a few drafting plastic triangles for setting up the gauge. I used one to set my stock gauge all the time. With the incra, I used it to set the gauge the first time, then put it away.
2459 posts in 240 days
85 days ago
if your table is in line with the blade ,
for quick reference ,
just loosen the handle ,
and run the gauge up to the rail ,
upside down ,
and tighten .
works good for most things !
