Curved Firepit Bench
Forum topic by EdsCustomWoodCrafts posted 05-22-2015 05:25 PM 2021 views 0 times favorited 11 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
782 posts in 1369 days
05-22-2015 05:25 PM
I want to make this curved firepit bench below, I saw someone make it without plans and I’m trying to design it on Sketchup , to no avail. The guy used pocket hole joinery …please help I really want to build this for a good friend of mine…..
If anyone has plans please feel free to share
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
11 replies so far
View CudaDude's profile
CudaDude
179 posts in 2334 days
#1 posted 05-22-2015 08:59 PM
No back and change the angle. This might work for ya.
http://www.woodstore.net/plans/outdoor/outdoor-furniture/1044-Made-in-the-Shade-Tree-Bench.html
-- Gary
View BroncoBrian's profile
BroncoBrian
542 posts in 1984 days
#2 posted 05-22-2015 09:44 PM
If you don’t use sketchup regularly, don’t beat yourself up. A good pencil and graph paper can be more useful and faster (well always faster). I have built from both and rarely prefer the computer. You can make a call out detail with pencil in a minute or two.
Cuda gave you a great start, you might need nothing more.
-- I think foosball is a combination of soccer and shish kabobs.
View jerryminer's profile
jerryminer
928 posts in 1467 days
#3 posted 05-22-2015 10:52 PM
Design should be fairly simple.
First, determine the height and depth you want (18” height is common. Depth between 24-30”)—-and the length of the bench and radius of the curve. (I drew an example below)
Build some simple 2×4 frames. Locate bottom stretchers and diagonal braces. Then lay out and cut the top “deck”
EdsCustomWoodCrafts
#4 posted 05-23-2015 12:28 AM
- jerryminer
jerryminer thank you so much for the models and there great , if I may ask a question about the geometry of the design as that is the main component of the bench that I’m having difficulty with
My design idea will have dimensions of
18” high x 72”wide and 18” deep following your exact design accept I’ll be putting 2×2 seat supports
1. The 2×4 bottom bench supports what’s the bevel measurement ( is it 15°In assuming this bevel cut is what gives the entire bench its curve!!
2. How to measure each lat in the seat while trying to achieve the curve
jerryminer
#5 posted 05-23-2015 03:39 AM
The angles will depend on the radius you want. I can sketch up a plan view if you give me the dimensions (overall width and radius)
jerryminer
#6 posted 05-23-2015 04:56 AM
Here is one example, using an 8-foot radius:
SketchUp is great for this kind of thing, but if you can’t get SketchUp to work for you, I would suggest laying it out on paper or something—-maybe scaled down to a manageable size—- so you can see the relationships and the angles.
EdsCustomWoodCrafts
#7 posted 05-23-2015 01:06 PM
SketchUp is great for this kind of thing, but if you can t get SketchUp to work for you, I would suggest laying it out on paper or something—-maybe scaled down to a manageable size—- so you can see the relationships and the angles.
- jerryminer
If you don t use sketchup regularly, don t beat yourself up. A good pencil and graph paper can be more useful and faster (well always faster). I have built from both and rarely prefer the computer. You can make a call out detail with pencil in a minute or two.
- jerryminer
Hi Jerry,
Thanks again and to be honest I quite like your 8’ radius… Your design shows a angled cut of 84.3° does that mean you cut 4.7° on the chop saw..
Could you please email me your plans so I can read them easier and maybe get it right in my head….
(ekeogh1975@gmail.com)
View cutmantom's profile
cutmantom
405 posts in 3061 days
#8 posted 05-23-2015 01:56 PM
Make it in three pieces, easier to move, can make as many as you want
jerryminer
#9 posted 05-23-2015 04:01 PM
Ed—I sent you an email. To get a 84.3 degree angle, set your saw to 5.7 deg. (90 – 84.3)
View helluvawreck's profile
helluvawreck
31393 posts in 2892 days
#10 posted 05-23-2015 05:09 PM
That is very attractive bench for a round fire pit.
helluvawreck aka Charles
BroncoBrian
#11 posted 05-24-2015 01:32 AM
Great work Jerry!
