| Forum topic by spanky46 | posted 85 days ago | 445 views | 0 times favorited | 18 replies | ![]() |
85 days ago |
Topic tags/keywords: question trick tip double face tape |
85 days ago |
I use carpet tape. I have a 2” wide roll that I’ve been using off of for several years. I rarely need a piece 2” wide so I’ve cut along the roll with a knife to make two narrower strips. One is about 3/4” wide. -- Until you spread your wings, you'll have no idea how far you can walk. |
85 days ago |
spanky , don’t even try the carpet tape , -- david ,new mexico ,allheart |
85 days ago |
Photo Mount spray isn’t thin? Carpet tape has worked very well for me for many years. -- Until you spread your wings, you'll have no idea how far you can walk. |
85 days ago |
dave -- david ,new mexico ,allheart |
85 days ago |
Spanky, I use double side tape a lot. I buy my tape at golf supply outlets. I use this most often when templet routing. The tape is usually thinner than carpet tape, but has excellent holding power and because the width is thinner, it isn’t as hard to separate as carpet tape can be. pkennedy -- P Kennedy Crossville, TN |
85 days ago |
I also use carpet tape. Just don’t use too much. It’s surprising how well it works with so little. -- I don't make mistakes, only design changes....www.dgmwoodworks.com |
85 days ago |
I usually use double sided “wood turner’s” tape. It is not as wide as carpet tape. It sticks very well, the only word of caution is to be sure that you have a good place to pry your parts apart w/o damaging the one you need. |
85 days ago |
I use carpet tape for “short run” projects. If it is going to be multiple runs I make a jig using toggle clamps if possible. -- Joe |
85 days ago |
Rockler sells a “turners” tape that I use, but like Longhairs says – plan on how to pry apart before hand. Best thing about this stuff is that it has never attacked the wood for me yet and tore grain out. |
85 days ago |
I also use turners tape from Woodcraft. Holds tight enough for roughing bowl blanks and template routing, but releases easy with a little angled prying. Leaves no residue at all. -- Dan-- Info for all @ http://www.hoistman.com |
85 days ago |
Im with Dan. It’s the greatest invention since sliced bread. -- Charlie M. "Woodworking - patience = firewood" |
85 days ago |
I use carpet tape. It’s messy. Guess I’ll try turners tape next. -- Praki, Aspiring Woodworker |
85 days ago |
Carpet tape. Cheaper than the “specialized” stuff. Just use small pcs. to get the job done. |
84 days ago |
I do inlays all the time on a CNC machine and use 3M9576 double sided tape. I believe it’s the ultimate tape for holding things down and easy removal. The adhesive leaves NO residue and rolls off easily with your thumb after things are pried apart. I use 3/32 balsa as a pad to mount the inlay material to the holder board, cut through the balsa with a sharp putty knive or saw through the balsa with a hacksaw blade if the inlays are tiny. I get mine form drillspotccom. It’s half the cost of turner’s tape and generally outperforms it. Carpet tape adhesive fills up my cutters so badly they smoke and evenutally break. -- M1911BLDR |
82 days ago |
double sided foam tape…3M I think. From the hardware store. holds well and comes off easy. -- If, in your life, you attain the means to help; you incur the responsibility to act. |
79 days ago |
Can’t remember what brand carpet tape I use, and won’t be in the shop for 10 days (vacation) but I can say, all carpet tape isn’t the same! |
79 days ago |
Unibond No More Nails is good stuff if you want a strong bond, and a peel that leaves no residue. It’s about 1mm thick and flexible, so it’ll handle surface imprefections. Don’t know if it’s sold in the US, but here’s a Canadian source: http://www.lepageproducts.com/products/detail.asp?catid=68&subid=177&plid=686 -- Late awakener.... |
79 days ago |
Spanky 46: Woodworkers Supply.com p.21. -- Remember--- one good turn-- gets most of the blanket!!!! |
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2362 |
LumberJocks.com Site Feedback
522 |
