3m adhesive backed sandpaper
Forum topic by DKV posted 05-21-2015 09:10 PM 1255 views 0 times favorited 8 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2468 days
05-21-2015 09:10 PM
For the last couple of years I’ve been using USA sandpaper exclusively. It’s kind of ok but not as good as the last time I used 3m. I recently bought some 3m at homedepot and used it on my palm sander. It is the adhesive backed paper. Now I can’t get the sheet off without tearing the rubber pad on the sander. Has anyone else had this problem? Have I been gone from 3m for too long and I’m doing something wrong? Help!
-- This is a Troll Free zone.
8 replies so far
View AlaskaGuy's profile
AlaskaGuy
4042 posts in 2273 days
#1 posted 05-22-2015 05:52 AM
Which 3 m paper? which sander? was the sander made for PSA paper? More info. How long did you leave it on the sander?
Did you try a heat gun to remove it. More info needed. ???????????????????????????????????????
View Monte Pittman's profile
Monte Pittman
28919 posts in 2302 days
#2 posted 05-22-2015 11:13 AM
I use hook and loop only. My previous experience with adhesive backed sandpaper gave me your results.
-- Mother Nature created it, I just assemble it.
View bigblockyeti's profile
bigblockyeti
5092 posts in 1685 days
#3 posted 05-22-2015 12:20 PM
I too have switched from PSA to hook & loop. My 6” DA still uses PSA backed paper and I use a heat gun or a few quick swipes from a torch flame to soften the adhesive to get it off.
View gfadvm's profile
gfadvm
14940 posts in 2654 days
#4 posted 05-23-2015 12:48 AM
Switch to hook n loop and use Abranet discs. You will be amazed at the longevity and dust collection. Be sure and get the Abranet backer pad.
View DKV's profile
DKV
#5 posted 05-23-2015 01:49 AM
gfadvm, the subject sander is a 1/4 sheet palm sander. I already use hook n loop for my random orbital. Thanks though…
gfadvm
#6 posted 05-23-2015 02:38 AM
oops
View Shadowrider's profile
Shadowrider
183 posts in 1173 days
#7 posted 05-23-2015 06:31 AM
Yes I have. If you leave it on for days (or weeks) at a time it kind of grows to the base pad. If you get it too hot it does the same. Don’t ask me how I know that. :D
I’ve also had hook and loop pull off the hook portion of my Ryobi palm sander but it afterall is a Ryobi.
View DKV's profile
DKV
#8 posted 05-23-2015 06:33 AM
Shadow, I get it hot and leave it on for weeks. Is there a conversion to hook and loop for 1/4 sheet sanders?
