Newbie questions
Forum topic by Sapling posted 92 days ago 322 views 0 times favorited 11 replies Add to Favorites Watch
View Sapling's profile
Sapling
2 posts in 92 days
92 days ago
Hello everyone. Just discovered this site a week ago and have spent a bunch of time viewing “project” pictures, reading comments, etc. You folks have a fantastic site, full of beautiful project pictures and commentary. I’ve always had an interest in woodworking, but seemingly never the time or motivating event to get me started. As of now the only tools that I have that could be remotely connected with woodworking are a few chisels, hammers and a chainsaw (ha, ha) but I’m fascinated by the prospect of turning some bowls, plates, etc. so I think I know what my first purchases will be. Now to a few basic questions, if you would be so kind as to indulge a novice with what are probably idiotic questions.
On my little ranch, and via properties of friends, I’ve got access to standing timber of probably over 20 different species of hardwoods. So I’m itching to get out there with my chainsaw and start building up an inventory of seasoned wood. I assume that it is very important to minimize cracking, etc. in the drying process, so: should I put wax, white latex paint or some other similar product on the cut ends immediately after cutting? Or let the logs “season” for a few days before “painting” the ends? I have a 3 sided cattle shed that I plan on using for air drying, unless you folks advise me that I need a 4 sided, fully enclosed structure.
Another question: If I were to cut down a big pecan tree, in hopes of having it sawed into boards for later on making a table, is it best to air dry the log for a period of time (how long?) and then take it to a sawyer? Or should I take it to the sawyer “green” and then either let him kiln dry the boards or take the boards home and air dry them?
I’ve got loads of other questions, but will wait a while before I pester you with them.
Thanks in advance,
Sapling
View Scott Bryan's profile (online now)
20793 posts in 721 days
92 days ago
Sapling, the ends of the boards should be sealed to prevent checking since wood will lose moisture faster through the ends. Any type of product that seals the wood- latex paint, wax, etc.- will work but the consensus is that Anchorseal, a product designed for this type of application, works best.
The second question I really do not have an answer for. If I were in that situation I would take them to a sawyer as soon as possible in order to start the drying process. Air drying will take about a year for each inch of thickness.
View Broda's profile
Broda
235 posts in 418 days
92 days ago
The wood will dry alot faster if its cut into boards while green (unseasoned) but taking them to a sawer can be expensive. Depending on how big the logs are, you may even be able to cut them into boards yourself. you can buy a chainsaw mill which aren’t too expensive to cut the logs into usable sizes so you can put them through your bandsaw; or better yet you can make your own chainsaw mill quite cheaply like this one- http://ablett.jp/workshop/csm.htm
but this all depends on what you already have and how much you are looking to spend
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
View Timbo's profile
Timbo
292 posts in 464 days
92 days ago
Welcome to Lumber jocks Sapling. Find someone willing to saw the logs first, they like it green. Not to discourage but some can be picky about what they cut. You can air dry under a roof, but go here and read up. http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr117.pdf
-- Tim: Remember, if it doesn't say Binford, someone else made it.
17141 posts in 476 days
92 days ago
Welcome to Ljs seem the others have this question handled
View WibblyPig's profile
WibblyPig
84 posts in 173 days
92 days ago
Check with Woodmizer http://www.woodmizer.com/us/index.aspx (it’s a portable sawmill company)
They used to keep a list of local owners you could contact to give you pricing for cutting up logs.
-- Steve, Webster Groves, MO
View notottoman's profile
notottoman
488 posts in 130 days
92 days ago
Question to the masses.
When a person with a large property has trees on it and wishes to cut a few down. .............................
............DO they replant say 2 or more for every one they fell?
Just thinking of the future generation
Sorry “Sapling” nothing personal. :-)
-- "Even small steps makes a distance." (Shawn Phillips, musician)
View spanky46's profile
spanky46
737 posts in 290 days
92 days ago
Welcome to Lumberjocks! Lots of friends with lots of talent!
I look forward to your projects and posts.
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
View Catspaw's profile
Catspaw
186 posts in 715 days
92 days ago
It seems to me everytime I take a tree out of my woods, mother nature has done a much better job of providing hundreds of little saplings around the tree I take out than I could plant myself.
Taking a “few” trees out of my woods will never affect future generations. My woods is quite capable of regenerating itself without my help. Unless you clear cut and trash a large section at a time, I’m sure mother nature can fend for herself.
Sawmills are cheap, particularly when you compare the price to the big box stores. Paint ends, saw green, sticker flat as possible, 1” = 1 year for air drying. The kilns around my parts are not really expensive to get your wood in a couple of weeks. Even at a $1 a bf for sawing and $1 a bf, it would still be cheaper the the store.
I’m guessing $$ varies quite abit from region to region. I would prefer to get a sawmill on site. It’s much easier to handle the sawn lumber (I get tired of lugging logs around.)
-- arborial reconfiguration specialist
View BTKS's profile
BTKS
492 posts in 364 days
92 days ago
I agree with the above posts. Saw green and sticker. I use a local sawyer who is set up with a large stationary bandsaw. He removes a 3/32 kerf instead of 3/8. About every 5th or 6th board is found wood instead of sawdust. I only pay 25 to 30 cents per board foot of milled wood. No smooth faces, just cut to my specs. I can have an entire flitch or have him focus on standard lumber sizes, depends on what I want. I would treat the ends as logs, lots easier than indiv boards.
As far as stickers go, I bought mine from the sawyer and just recycle them over the years. This way, they are all the same thickness on all four sides, much flatter stack. Don’t forget to weigh down the top with cinder blocks or something heavy.
Heads up, pecan and hickory WILL attract bugs. I recommend kiln drying for these two species. I have asked sawyers and they don’t know of anything to treat the wood with to keep the bugs and beetles away that won’t stain the wood. You might ask an exterminator.
Hope this helps. Just a few things I’ve run into the last several years. BTKS
OH YEA, WELCOME TO LJ’S!!!!
View Bill White's profile
Bill White
111 posts in 860 days
92 days ago
I do not suggest that the logs be stored uncut unless the bark is removed first. Bugs, BUgs, BUGs, BUGGGGGGS will eat your wood. Rough saw and sticker. Oh, buy a moisture meter.
Welcome.
Bill
Sapling
2 posts in 92 days
90 days ago
Thank you very much for all the comments and links. They are very helpful and informative.
