Picture frame miter clamp
Forum topic by Innovator posted 1391 days ago 13322 views 2 times favorited 21 replies Add to Favorites Watch
View Innovator's profile
Innovator
3584 posts in 1611 days
1391 days ago
Topic tags/keywords: tip clamp
I have 4 corner clamps for gluing up picture frames. I bought them in my youth when cheap was the right price. Today I spent over an hour trying to get a frame squared up. I am in need of a new set of corner clamps.
What clamps are others using to hold their miters for gluing? I know there are a lot of choices out there from individual corner clamps to self centering all in one clamps as well as nailers that are a clamp.
I am not married to one system over another I am just looking for a good clamp that I will not feel I wasted my money on.
Any suggestions would be great.
Thanks
Rob
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
21 replies so far
View GMman's profile
GMman
3885 posts in 1895 days
#1 posted 1391 days ago
GMman
#2 posted 1391 days ago
GMman
#3 posted 1391 days ago
I have those clamps but I like to use biscuits on my picture frames and do one corner at one time I just hold them tight for a few minutes then move to the next one it’s a lot faster than trying to work those clamps.
GMman
#4 posted 1391 days ago
Check out the ones I did.
View Bricofleur's profile
Bricofleur
964 posts in 1391 days
#5 posted 1391 days ago
Take a look at these from Lee Valley. Even is they are cheap (clearance) they are great. Once clamped, you can let the glue dry or you can pin the corners with a pneumatic nailer. Since I own four of them, a frame is done is minutes.
http://www.leevalley.com/wood/page.aspx?c=1&p=62624&cat=1,44047
Best,
Serge
www.atelierdubricoleur.spaces.live.com
-- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com
GMman
#6 posted 1391 days ago
Bricofleur…I have those and they don’t work that well.
GMman
#7 posted 1391 days ago
Serge I was looking at your www.space what do you call those red clamps,they seems to work very well.
View Rob Drown's profile
Rob Drown
647 posts in 2031 days
#8 posted 1391 days ago
http://www.woodcraft.com/Images/products/03W52.jpg
These clamps are excellent. Very stable and quick. They are pricy which is why I only have one.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
Bricofleur
#9 posted 1391 days ago
They are Bessey K-Body clamps. I own the discontinued model. Take a look at the new ones from Lee Valley.
http://www.leevalley.com/wood/page.aspx?c=1&p=60315&cat=1,43838,43844
Pricy also, but very effective. But for miters, I rely on the corner clamps I posted earlier. If I were doing lots of miters, I would go for the one Rob Brown posted, which I believe are also made by Bessey.
Best,
Serge
GMman
#10 posted 1391 days ago
Merci Serge
View jack1's profile
jack1
1822 posts in 2225 days
#11 posted 1391 days ago
There is a cast iron frame holder by the same company that makes that guillotine that shaves paper thin slices of frames to match them up, I’ve seen them used in professional frame shops. I am not sure who carries them now but I think Rockler did carry them both and they weren’t that spendy. I have some of the above clamps and also use a home made jig of 2×4’s attached to 3/4” sheet stock that are aligned in an accurate 90 degree configuration with a space between the boards to allow pinning, . You can then rotate the frame and add another side until you are done. You have to be sure your pieces are cut accurately and check diagonally for accuracy. I’ve used this jig for picture frames, doors, boxes, cabinets and special table tops. Works well.
View niki's profile
niki
426 posts in 2278 days
#12 posted 1390 days ago
I made the corners and bought the strap from one of the car supplies stores…they come in a variety of lengths and strengths…this one is 1½” wide and 12’ long…
niki
GMman
#13 posted 1390 days ago
niki…you have a great jig.
noto….your right exact 45*.
I use regular biscuits.
Bricofleur
#14 posted 1390 days ago
Here is another easy way using parallel clamps and corners blocks. My corner blocks are made from ¾” plywood. I use Bessey K-blocks to support the corner blocks but any shopmade riser blocks will do.
Niki – I like the dowels at both ends of your measuring sticks. Clever !
Best,
Serge
Innovator
#15 posted 1389 days ago
Thanks all for the feedback.
It is much appreciated.
Rob
