Leveling Tables
Forum topic by Smitty_Cabinetshop posted 05-21-2015 02:12 PM 1058 views 0 times favorited 5 replies Add to Favorites Watch
Smitty_Cabinetshop
15280 posts in 2582 days
05-21-2015 02:12 PM
Saw this video recently that shows using a table saw to level what is essentially a small stool. A couple questions:
What’s your approach to leveling when the project is large, as in, table sized? Is adding those leveling bolts / pads the best way? That isn’t always what the piece calls for, though. And, what if it’s a case piece with a bit of wobble?
Thanks for any suggestions.
5 replies so far
View DrDirt's profile
DrDirt
4423 posts in 3706 days
#1 posted 05-21-2015 02:42 PM
I use the tablesaw top like Gary as my ‘reference flat surface’
But I use a Sticky back (PSA) 5 inch sanding disk stuck to the table (80 grit) and sand/scrub the leg that is too long.
Gary’s method obviously works, and at such shallow cuts isn’t unsafe…. I just never thought to do it that way.
Smitty_Cabinetshop
#2 posted 05-21-2015 06:51 PM
Sanding disc stuck to the floor (larger items) does sound like a good solution Doc, thanks. First and foremost, make it level though, right? :-)
View Ghidrah's profile
Ghidrah
667 posts in 1186 days
#3 posted 05-21-2015 07:21 PM
Depending on how bad it is I also use a paper thin flush cut saw
-- I meant to do that!
Smitty_Cabinetshop
#4 posted 05-21-2015 07:31 PM
Also a good idea, thanks Ghidrah. I can see that being similar to a method for closing up mitered dovetails.
View stefang's profile
stefang
15881 posts in 3298 days
#5 posted 05-22-2015 09:45 AM
The sandpaper double taped to your assemble table or the floor is absolutely the best way. It’s a bit slow, but very effective and I can’t think of a better way to do it without risking breakout on the edges.
