Need advice on veneer (rookie)
Forum topic by rwe2156 posted 05-21-2015 02:07 PM 717 views 0 times favorited 5 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2881 posts in 1447 days
05-21-2015 02:07 PM
I’m looking at re-veneering some antique treadle sewing cases my wife is restoring.
I’m mainly wondering about which way to go on purchasing the veneer:
I can get 4×8 sheets and lots.
I’m thinking the 4×8 sheets will be easier to use (no edging) but I’m thinking maybe there will be some matching issues.
I’m thinking I can bookmatch if I go with serial cut lots.
Which way do you guys go and what sources can you recommend? So far I’ve looked at Oak Wood Veneer and Veneering Supplies.
What thickness would you use for a table top?
5 replies so far
View shipwright's profile
shipwright
7966 posts in 2764 days
#1 posted 05-21-2015 02:25 PM
I would use raw veneer. The sheet sizes are usually paper backed or two ply and the veneer is scary thin.
My advice would be to first have a look at Certainly Wood's special thickness veneer. It can be bought in 1/16” and it is way easier and better to work with than the 1/42” that is now industry standard.
If you can’t find what you need there, then you will have to go to the thinner stuff.
If they really are antique you should use hide glue. I would recommend Old Brown Glue but any hide glue will get it done. I use only hide glues for veneering as a matter of preference but with antiques you should use it because it will be what was there originally.
View jmartel's profile
jmartel
7806 posts in 2116 days
#2 posted 05-21-2015 02:55 PM
I buy all of my veneer through CertainlyWood. If you order multiple sheets from the same lot number from them, it comes sequential.
View FellingStudio's profile
FellingStudio
93 posts in 1648 days
#3 posted 05-21-2015 03:00 PM
Yes, definitely use raw veneer. Another quality supplier is veneersupplies.com.
Get, or make yourself a veneer hammer and do it old school style with hide glue. There’s a few videos out there on youtube showing the technique.
For what it’s worth, if the veneer on the cases is just lifting (Ie. not broken and missing), it can be repaired with a little moisture, a heat gun, and your veneer hammer.
-- Jesse Felling - http://www.fellingstudio.com
rwe2156
#4 posted 05-21-2015 04:52 PM
I would like to get the 1/16 but can’t find any with the figure I need.
Certainlywood doesn’t have white oak.
Just remembered I have some QSWO with decent figure so I’ve decided to resaw and see what I can get.
Thanks for the responses.
shipwright
#5 posted 05-21-2015 04:53 PM
+1 on the veneer hammer. That is how I would do it but there is a learning curve. I suggested OBG (liquid hide glue) because it has a good open time and is used just like the pva that you are likely using now.
I have a “Hide Glue for Beginners” blog that shows hammer veneering and discusses hide glue techniques and advantages in some detail.
