| Forum topic by dalec | posted 93 days ago | 414 views | 0 times favorited | 13 replies | ![]() |
93 days ago |
I have a low end digital caliper that I have been using with the thought that it is a whole lot more precise, then again maybe not, than using a tape measure, especially with my vision not being nearly as good as it use to be. The digital caliper displays in mm, in fractional (64th) and digits. I found that opening the caliper when it initially displays 1/16” and to the point the display changes to 5/64” is pretty noticable. The digital reading for 1/16” ranges between 0.0560” and 0.0705” a range of 0.0135”. It seems to be a lot of difference. I don’t want to be obsessive about my measurements, but …. How many of you use digital calipers and do you use the mm, fractional or digits? Seems using digits rather than fractions is more accurate. How accurate is accurate enough for measurements under 6”? or that matter what level of accuracy do you expect over 6”? Dalec |
