Level Legs the Easy Way
Forum topic by pjones46 posted 05-21-2015 05:12 AM 1273 views 0 times favorited 3 replies Add to Favorites Watch
View pjones46's profile
pjones46
1001 posts in 2606 days
05-21-2015 05:12 AM
Topic tags/keywords: tip trick tablesaw
An old timer showed me this years ago but just found a video, where as some people say, pictures are worth many words.
Here is a video of a good way to Level Legs the Easy Way.
-- Respectfully, Paul
3 replies so far
View JeffP's profile
JeffP
573 posts in 1355 days
#1 posted 05-21-2015 11:35 AM
Very cool. Thanks for posting it.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
pjones46
#2 posted 05-21-2015 03:38 PM
Thanks Jeff.
As Gary says in the video this method is for small tables, stools chairs and the like.
It really does not address larger tables or when your floors are uneven which can still affect the level. At that point you have to resort to other means such as shims, screw levelers, or even stick on cork or wool felt.
Ideally the tfurniture/table will be leveled as you go so that the finished project is perfectly level. However, I have had times when something just doesn’t work out right or moves later and the table becomes unlevel. If the table is only slightly out you can use a block plane to trim the long legs
Sometimes turning/repositioning how a furniture piece sits will be enough for the purpose but in allot of cases that is not practical to do. So, what’s the answer? Cross the bridge when you come to it, or just supply your furniture piece with screw levelers.
View Roger's profile
Roger
20923 posts in 2767 days
#3 posted 05-22-2015 11:50 AM
Nice tip.
