A Question on Box Hinges
« back to Joinery forum
Forum topic by tpmwoodworker posted 05-20-2015 10:25 PM 676 views 0 times favorited 5 replies Add to Favorites Watch
View tpmwoodworker's profile
tpmwoodworker
19 posts in 1112 days
05-20-2015 10:25 PM
Topic tags/keywords: hinges wooden box brass hinges
Greetings fellow lumberjocks,
I apologize if this is not technically a joinery question. But it’s as close as I could figure among the different forums.
I’ve been working on improving my joinery skills by making a series of wooden boxes with dovetails. And I’m planning on making my next projects with hinges recessed on the inside of the inside of the box rather than just screwed in on the outside on the back.
My problem is that I buy all my hardware and accessories online. And while I have the skills to cut the recesses, I’m not sure which hinges to buy that are made specifically for this as opposed to what I described as on the outside/back.
For instance, I’ve looked at these two on Rockler but I don’t know if they’re different in terms of what I’m doing or if it doesn’t really matter which of these kinds of simple hinges I buy to do what I’m describing.
http://www.rockler.com/brusso-solid-brass-small-box-stop-hinges
http://www.rockler.com/narrow-miniature-solid-brass-hinges-with-non-removable-pin-polished-brass-finish-smallest-to-largest
Any pointers on this front I’d be really grateful for. I’m just hoping not to order online and finally get them and then realize I’ve bought a kind that won’t work for what I’m trying to do.
Thanks, all.
Josh
-- Newcomer to Woodworking, Looking to Learn More
5 replies so far
View jerryminer's profile
jerryminer
890 posts in 1351 days
#1 posted 05-20-2015 10:31 PM
Either of those two hinges could potentially work for your project.
The differences:
The first one is a Brusso hinge—-a top-quality US-made hinge. That model is also a “stopped” hinge, so it prevents the box lid from opening past about 95 degrees.
The second is a more standard butt hinge—-no stop, and probably not as precisely made (i.e. it will have more slop).
tpmwoodworker
#2 posted 05-20-2015 10:34 PM
Okay, this is very helpful and what I thought but I haven’t been able to find any confirmation. The quality difference I understand. At this point, I don’t think my skills merit the 30 bucks for the Brusso. And I’m not sure my wallet is up to the challenge either. The stop I don’t think I want/need. So basically it sounds like either of these hinges could be mounted in either of the ways I describe about. Just a matter of cutting the recesses appropriately?
Thanks again for the help.
View jmartel's profile
jmartel
7687 posts in 2059 days
#3 posted 05-20-2015 10:38 PM
Both should be mortised in. The Brusso is a much nicer hinge. But, if the budget doesn’t allow it, the other will work as well. It’s just thinner and stamped rather than machined like the Brusso ones.
View Jimarco's profile
Jimarco
15 posts in 1017 days
#4 posted 05-21-2015 01:07 AM
Josh, if you are going for the non-Brusso hinges, Rockler has some inexpensive stop hinges that will save you from adding a chain to keep the lid open. http://www.rockler.com/brass-plated-small-box-stop-hinge There is also a Piano Hinge 8” http://www.rockler.com/105-degree-stop-hinge-8-inch that comes in different finishes.
Lowes carries a variety of small/minature brass box hinges in different sizes. They are not stop hinges but do well. http://www.lowes.com/pd_311939-1277-890293_0Z1z1407o__?productId=3355480&Ns=p_product_price|0&pl=1&Ntt=hinges
When recessing/mortising for the hinge, you can take out the total depth of the hinge from the bottom meaning the top of box. This would leave the bottom of the lid with a non recessed/mortised hinge screwed to it and laying flat. The top of the backside of the box holds the entire hinge in its recess.
Hinges are always a challenge for me and a big help/must have is the self-centering bitshttp://www.rockler.com/rockler-insty-drive-self-centering-bits. Even at the non-sale price, they are worth every penny!
View AandCstyle's profile
AandCstyle
2980 posts in 2166 days
#5 posted 05-21-2015 01:26 AM
Josh, take a look at these hinges from Horton Brasses. They are good quality and reasonably priced. I used them on this box. HTH
-- Art
