Attaching a Company Board to a table.
Forum topic by Beeguy posted 90 days ago 276 views 0 times favorited 4 replies Add to Favorites Watch
View Beeguy's profile
Beeguy
29 posts in 532 days
90 days ago
Topic tags/keywords: table farm table
Hello Everyone,
I have a question regarding a farm table I am in the processing of building. The top is 86”x39” and 9/8” thick. I made it out of wormy soft maple. The legs and aprons are made from plain soft maple. The aprons are 3 ½ “ wide and almost 7/8” thick. The tabletop extends 8” past the apron on the long ends.
I would like to add an 18 inch “company board” to one side. While I have occasionally seen these I have never been able to look underneath the table to see how it was attached. My thought is to use two hardwood strips that would extend from the company board, through notches in the apron to a reasonable distance underneath. Then it should easily slid in and out when needed.
My concern is the apron will be acting as a fulcrum and bearing all the weight. Not that this will be heavy but I am concerned if someone leans on it or uses it for support when getting up from the table. Will the apron support the weight or should I attach an additional bracket of some sort directly to (near the end) the table top.
Any thoughts would be appreciated.
-- Ron, Kutztown, PA "The reward is in the journey."
View Kindlingmaker's profile
Kindlingmaker
1471 posts in 422 days
89 days ago
I have never done this but have an idea… Put square saddle clamps under the table then have your company table with two long hardwood runners that would slip into the clamps, then a stop pin. Sort of like some baby high chairs with the removable, adjustable table…
25801 posts in 1296 days
89 days ago
A square hole in the apron 8” back would not really be visable. I also like the idea of making a support sustem under the table where the company board slides in to hold.
View Rob Sukach's profile
Rob Sukach
2 posts in 88 days
88 days ago
I snapped a couple of pics of our kitchen table – store bought – that has the end-leaves I think you’re describing. I hope they upload ok, this is my first post.
http://img16.imageshack.us/i/img4961i.jpg/
http://img530.imageshack.us/i/img4962r.jpg/
http://img405.imageshack.us/i/img4963.jpg/
the long runners pass through holes in the apron. they are secured with a sliding bolt, the type you typically use on a screen door, that slides into a notch in one of the runners (you can see it in the upper right corner of pic 3 above).
Hope it helps,
Rob
-- Rob Sukach, Grapevine, TX
View Brian's profile
Brian
51 posts in 607 days
85 days ago
I’ve made a few tables as you’ve described and IMHO the aprons will be fine.
What hole size you plan on making?
-- http://www.brianpenning.com/
