Newbie Chisel Question
« back to Hand Tools forum
Forum topic by Spur posted 05-20-2015 01:05 PM 811 views 0 times favorited 4 replies Add to Favorites Watch
View Spur's profile
Spur
87 posts in 2055 days
05-20-2015 01:05 PM
Topic tags/keywords: chisel
I purchased a set of Stanley sweethearts and did my own attempt at flattening and sharpening. After the first few uses I noticed my fingers were getting cut up pretty good despite not touching the edge. I realized that the flattened part of the chisel on the corners was so sharp, even as a 90 degree angle, that it was the cause of my issue. Is there any reason I would not want to ease those edges on the chisel with a little sandpaper? To prevent my fingers from turning to hamburger? Thanks!
-- Henryk, South Carolina
View diverlloyd's profile
diverlloyd
2774 posts in 1885 days
#1 posted 05-20-2015 01:29 PM
I take a small stone and go down the the sharp edges you don’t want. It doesn’t take much to knock the sharpness down. Mine maybe a wee bit rounded, which is fine but always forget to do it until I see the cuts just pat my first knuckle on my index fingers. If you are worried about your the corners of the cutting edge just slightly round over the edge but stop a inch from the cutting edge.
View Spur's profile
Spur
#2 posted 05-20-2015 02:09 PM
Thanks Lloyd! That cut above the knuckle is the exact one I am talking about! And since I switch between hands I get it on both :)
View Tim's profile
Tim
3812 posts in 1989 days
#3 posted 05-20-2015 02:24 PM
I’ve seen reference to easing the non cutting edges of a chisel being a standard thing to do when tuning up a chisel. Leaving the inch near the cutting edge alone doesn’t seem like a bad idea but rounding all the way doesn’t seem to harm anything either.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1242 days
#4 posted 05-20-2015 07:30 PM
Yes you should definitely ease those edges and stop before you get to the cutting edge. Over the course of several years you won’t remove even so much as 1/16 inch of the length of the chisel, so you can get pretty close to that cutting edge without worry.
-- Talent, brilliance, and humility are my virtues.
