What is the best preservative for an equipment trailer deck?
Forum topic by TopamaxSurvivor posted 1367 days ago 2523 views 0 times favorited 14 replies Add to Favorites Watch
TopamaxSurvivor
13194 posts in 1848 days
1367 days ago
Topic tags/keywords: deck preservative trailer
I have a used equipment trailer that is well weathered. I am wondering what is the best way to preserve and lenghten the life of the wood deck?
14 replies so far
View Dan'um Style's profile
Dan'um Style
10811 posts in 2155 days
#1 posted 1367 days ago
penetrating oil finish is what I would suggest
-- keeping myself entertained
View degoose's profile
degoose
6598 posts in 1527 days
#2 posted 1367 days ago
Good quality decking oil would be my choice… anything that soaks in.
View SnowyRiver's profile
SnowyRiver
45987 posts in 1653 days
#3 posted 1367 days ago
I would think a good deck oil would work. If the wood is really dried out, you might need several coats.
-- Wayne - Plymouth MN
View Gene Howe's profile
Gene Howe
3200 posts in 1601 days
#4 posted 1367 days ago
I’m cheeeeeep. I use old motor oil. E/O year.
Applied with a sprayer attachment and compressor. Could use a brush but I feel that the pressure from the compressor does a better job.
I get very little on the ground.
It never dries. Let it soak in.
Gene
View BTKS's profile
BTKS
1919 posts in 1636 days
#5 posted 1366 days ago
We’ve used motor oil in the past but had a seeping top coat that made for slick work. Used vegetable oil from restaurant fryers works great. We treated my in-laws dock several years ago and it’s holding up great. It was treated wood to start with but it really seems to help. Better yet, the veggie oil doesn’t run into any EPA problems or ground water contamination. Oh yea, the best part, it’s usually FREE for the asking when a restaurant changes the fryer oil. Hope this helps. BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View gerrym526's profile
gerrym526
265 posts in 1981 days
#6 posted 1365 days ago
I learned from Bob Flexner, the finishing expert, that any wood exposed to the elements has its cellulose structure break down from UV. All the hype about the damaging effects of water are just that-hype. Bob recommended a solid body exterior stain, or latex paint, as the best shield against UV and the wood breaking down. Any clear coat that’s applied to wood (for example Thomsons Water Seal) is worthless in keeping the wood from softening, and eventually rotting, from sunlight. More pigment in the material=more protection.
-- Gerry
TopamaxSurvivor
#7 posted 1365 days ago
That’s what i thought about the UV. Wondering if there is a superiior product??
gerrym526
#8 posted 1365 days ago
I think any good quality solid body exterior stain will be fine. Benj Moore, Behr, etc. should work.
-- Gerry
TopamaxSurvivor
#9 posted 1362 days ago
I talked to Sherwin Williams today. They didn’t think their stains would hold to to equipment driving on and off or throwing and dragging materials on and off. I found some penetrating oil with 99% UV protection called Penofin penetraing oil finish. I’m going to try it. The solid bodied strains on our deck don’t stand up to dog and foot traffic for more the about 3 years before they start to peel. Flat work surfaces are tough.
TopamaxSurvivor
#10 posted 1346 days ago
Just put this link on for another thread, may as well finish this one out too ;-))
This is what is fially used http://www.penofin.com/products_logon.shtml
View UnionLabel's profile
UnionLabel
660 posts in 1372 days
#11 posted 1346 days ago
I use Herculiner coating. Its tough, UV resistant, and durable. Kit comes with 4 rollers. Prep work is the hardest part of the whole deal. NO WAXES, OILS or RUST. Looks great and lasts. Also helps items from shifting around. Stuff adheres to anything, including you. Equipment trailers are an investment.
-- Methods are many,Principles are few.Methods change often,Principles never do.
TopamaxSurvivor
#12 posted 1346 days ago
Now you tell me ;-))
UnionLabel
#13 posted 1346 days ago
Sorry, just saw the posting and thought I would add my 2 cents. Have been using the stuff for years. I have even coated the underside of my trailer fenders with the stuff and reduced rock damage. Beats the spray undercoating hands down.
TopamaxSurvivor
#14 posted 1346 days ago
I was just joking ;-)) I did read the instructions. The decking is 6 yrs old when I got it. The penetrating UV protection is probably better. I would most likely had adhesion problems with the old wood and Herculiner. I have had such a terrible time getting the normal solid body deck stains to last without chipping off, I was very skeptical abut the trlr deck. I think I’ll strip the house deck and use this stuff next time on it too.
