What is the best way to create this joint?
« back to Joinery forum
Forum topic by _Larry_ posted 05-20-2015 01:02 AM 813 views 0 times favorited 6 replies Add to Favorites Watch
View _Larry_'s profile
_Larry_
9 posts in 1099 days
05-20-2015 01:02 AM
Topic tags/keywords: joinery joints sofa furniture curves joining
Hi,
This is my first post.
I am new to woodworking.
What would you suggest for creating a joint such as the one pictured below?
I am interested in joining the sofa leg to the sofa arm support.
I do not want to have exposed end grain and I am skeptical that a end grain mortise is the best option.
What do you think?
Thanks!
View BurlyBob's profile
BurlyBob
5491 posts in 2261 days
#1 posted 05-20-2015 03:33 AM
Larry that picture leaves a lot to be desired. It doesn’t give anyone much to look at but dark wood. Can you get anything better?
View HerbC's profile
HerbC
1755 posts in 2855 days
#2 posted 05-20-2015 02:55 PM
My guess would be that the front and side stretcher joints are both mortise and tendon joints into the bottom of the arm support. On cheaper furniture they might be dowel joints.
It looks like the side joint be include a peg from the side, perhaps drawbored…
Good Luck and remember…
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
_Larry_
#3 posted 05-20-2015 03:20 PM
Sorry Bob, it was grabbed from the internet.
I think I will do a glue up to make the leg and arm support, rather than try to join them.
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#4 posted 05-20-2015 03:47 PM
Cut it from a single piece of wood or miter joint with dowels.
MrUnix
6703 posts in 2194 days
#5 posted 05-20-2015 03:51 PM
+1
I’d make the leg extend all the way up to the arm rest – all one single piece. Mortise and tenon the rest (or maybe dowels) to support the weight on the seat.
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1210 days
#6 posted 05-20-2015 04:03 PM
How about a sash joint from the leg to the support, that would let you have that long tapered shape and still have a good reference surface for the M&T you will be cutting on the frame pieces where they join the leg. You could reinforces the sash joint with dominoes, biscuits, or dowels.
-- Talent, brilliance, and humility are my virtues.
