Live edge fireplace mantel
« back to Joinery forum
Forum topic by fisherdoug09 posted 05-19-2015 02:49 PM 934 views 0 times favorited 4 replies Add to Favorites Watch
View fisherdoug09's profile
fisherdoug09
122 posts in 2696 days
05-19-2015 02:49 PM
Topic tags/keywords: joining
Hello fellow woodworkers. I want to build a live edge fireplace mantel out of some 3” pine I have. Here lies the problem, I want to put it behind my free standing gas stove which is going to be in a corner, and do the mantel at 45 degrees in the corner. Any suggestions on getting the corners to come together at a 45 and still have the flow of the live edge? This will be an inside mitre.
View BurlyBob's profile
BurlyBob
5543 posts in 2287 days
#1 posted 05-19-2015 03:11 PM
Cut it very carefully!
View Jerry's profile
Jerry
2654 posts in 1670 days
#2 posted 05-19-2015 03:11 PM
Imagine cutting a V at 45° angles with the widest part of the V being on the live edge. Once you cut out that V, the two pieces should come together nicely. They may not be perfect depending on how irregular the live edge is.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View SirIrb's profile
SirIrb
1239 posts in 1252 days
#3 posted 05-19-2015 03:38 PM
If it is an inside miter then the only deviation in the live edge will be the kerf, assuming I read the description right. The mantle is in the corner and the mitered edges are going along each wall. If it is the other way then you will have to make the cut and then treat it like you would dental molding: keep trimming the edge until you get a nice match. I doubt it will be perfect.
SirIrb
#4 posted 05-19-2015 05:10 PM
I flipped the miter in my mind. Sorry. Disregard.
