What is the best assortment of planes for a noobie?
Forum topic by ericandcandi posted 08-25-2009 05:04 AM 1053 views 0 times favorited 7 replies Add to Favorites Watch
View ericandcandi's profile
ericandcandi
152 posts in 3484 days
08-25-2009 05:04 AM
I realized quickly that power tools alone ain’t gonna cut it. I needed a plane to knock an edge off because the position of a router would be down right dangerous. The only woodstores in northwest Louisiana are big box. Variety is lacking and I just wanted to get the right ones. I probably will order online at woodcraft or rockler but if someone knows of a better place please let me know…...thanks in advance
I would be using them for general woodworking, cabinet and furniture stuff.
-- ericandcandi in Louisiana- Home of the "LSU Tigers"
7 replies so far
117063 posts in 3544 days
#1 posted 08-25-2009 05:12 AM
Woodcraft planes are suppose to be good. If you only have one plane get a low angle bench plane.
ericandcandi
#2 posted 08-25-2009 06:19 AM
Thanks a1jim. I am thinking maybe purchasing the 3 most used planes in a woodworking shop.
View Roper's profile
Roper
1389 posts in 3680 days
#3 posted 08-25-2009 06:21 AM
a block plane, a number 4 ,and a shoulder plane is a good start.
-- Roper - Master of sawdust- www.roperwoodturning.com
View John Gray's profile
John Gray
2370 posts in 3852 days
#4 posted 08-25-2009 06:31 AM
2 Block planes like a Stanley 110 and a low angle one like the Stanley 60 1/2. And a #4 smoother.
View knotscott's profile
knotscott
7980 posts in 3342 days
#5 posted 08-25-2009 11:11 AM
If I were going with 3, I’d start with a low angle block, and a smoother (#3, #4, or #4-1/2), and a small jointer (anything from #5-1/2, 6 or 7 will do fine). It really depends on what you want to do, how you set them up, and how they feel to you. You can do alot with 3, and can add to them later if you want.
I’d be far more inclined to check out the fine older planes from some of the veterans on wwing forums, or Ebay….Stanley Bailey (or Bedrock), Record, Millers Falls, Sargent, Union, etc. Many older planes are actually less work than a tuning a new one, but they’ll all need some setup time, and an edge.
Enjoy!
View mikeH's profile
mikeH
98 posts in 4258 days
#6 posted 08-25-2009 03:07 PM
i just started reading Chris Schwarz’s book handplane Essentials. His reccomends; low-angle block, shoulder plane,smoothing plane,and jointer plane. He make good arguments for each one. what i have seen so far is that he tell what each plane is good for and why. so far it has been a good read.
-- mjhaines
View PurpLev's profile
PurpLev
8534 posts in 3615 days
#7 posted 08-25-2009 03:21 PM
a #5 would be a good all-around plane if you only can have one (can be used as a smoother, or for jointing) but if you can have more than one then I would say:
block plane, #4, #6/#7/#8
and if you can add one more, then:
shoulder plane
