Finishing room size in your shop
Forum topic by bonesbr549 posted 05-18-2015 05:27 PM 1788 views 0 times favorited 11 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1569 posts in 3151 days
05-18-2015 05:27 PM
As i plan my shop I want a seperate finishing room. What size room do you work with? I tend to make larger pieces like wine cabinets. Curio’s, piesafes etc.
11 replies so far
View HornedWoodwork's profile
HornedWoodwork
222 posts in 1298 days
#1 posted 05-18-2015 06:11 PM
I have a seperate area in my basement away from the shop and all the dust to finish. I have a bench and cabinets setup up at about 2 feet by 6 feet for smaller pieces, and a platform about 6 by 12 for larger pieces. I find this to be adequete for everything, though larger dining room tables and cabinets can be hard to get in and out of the basement.
-- Talent, brilliance, and humility are my virtues.
5035 posts in 2577 days
#2 posted 05-18-2015 08:44 PM
I don’t have a room, but drop plastic from the ceiling on an 8’x8’ frame. When you spay and try to move around a moderate sized piece it gets quite crowded inside the plastic tent..
View barada83's profile
barada83
86 posts in 1270 days
#3 posted 05-18-2015 08:46 PM
I have an 8×8 as well. TO avoid walking around, I also have a large plywood turntable I put projects on to spin them when spraying.
-- Mike
View BurlyBob's profile
BurlyBob
5841 posts in 2349 days
#4 posted 05-19-2015 02:24 AM
I’m in a garage and only get to dream of a finishing room!
View Beams37's profile
Beams37
166 posts in 1274 days
#5 posted 05-19-2015 02:30 AM
Sounds like champagne problems to me …. BUT I would say go for the biggest room you can fit into your shop.
-- FNG ... On a quest for knowledge.
View JAAune's profile
JAAune
1825 posts in 2401 days
#6 posted 05-19-2015 02:54 AM
Size it for the majority of the work you do then install large double doors for entry. One day you’ll get a project that is 3 feet longer than the finishing room and you’ll be able to open the doors and hang sheeting to extend the space.
We occasionally work on pews 20+ feet long but opted for a 14×14 finishing room. It’s not worth taking up permanent shop space for projects that only show up once a year or so.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2615 days
#7 posted 05-19-2015 03:23 AM
I put a 9×10 finishing room in my shop. That’s stud centers, so it netted out to 8’6” x 9’6”. It is a good size to do everything up to a dresser. I’ve found it a bit challenging to fit larger doors and table tops for spraying. While I have a large door (4’ wide), it isn’t located where I could have have a long item sticking out. Probably isn’t wide enough, either.
If you spray, you’ll want to think about where you’ll let things dry. For anything larger than a pen, you’ll want to plan on having only one item at a time in the spray area.
-- Mark Kornell, Kornell Wood Design
bonesbr549
#8 posted 05-19-2015 12:22 PM
Thanks folks. I spray if at all possible. Hated using the same room to build / finish. I’m thinking 10×10 and I like the double door idea.
View jesinfla's profile
jesinfla
275 posts in 1221 days
#9 posted 05-19-2015 02:04 PM
While not really a “room”, I’m currently planning on a spray/finish booth made from pvc and plastic sheeting.
Not sure yet how big or even where I’m going to store it.
Like many, I mostly work in part of my garage so there’s really no room for an actual space :(
Woe is me LOL
-- They said I could be anything... So I became Sarcastic! They also said making drawers is easy... I think they lied :(
bonesbr549
#10 posted 05-19-2015 05:29 PM
While not really a “room”, I m currently planning on a spray/finish booth made from pvc and plastic sheeting.
Not sure yet how big or even where I m going to store it.
Like many, I mostly work in part of my garage so there s really no room for an actual space :(
Woe is me LOL
- jesinfla
I hear ya. I started in the dining room of our one bedroom apartment. Moved up to a 10×12 spot to a 2 car garage to my basement.
Getting ready to build my last place I’ll do it right the last time.
Cheers
View shipwright's profile
shipwright
8031 posts in 2882 days
#11 posted 05-19-2015 11:32 PM
Mine is ten by ten in the back corner of my thirty by forty. It’s nice not only because I can keep dust out but as a small space it’s easy to bring the temperature up when it’s chilly outside with just an oil circulating electric space heater.
Make sure to use a no-spark exhaust fan if you plan to spray anything volatile.
