Once Again I Need Help
Forum topic by lew posted 05-18-2015 05:05 PM 974 views 0 times favorited 13 replies Add to Favorites Watch
View lew's profile
lew
11939 posts in 3657 days
05-18-2015 05:05 PM
Topic tags/keywords: question drawer
I have been working on a custom made humidor now I have a problem and don’t know how to solve it.
The customer picked the design from a picture and then made modification/additions. I’m not experienced enough to have had the foresight to realize the problem that was going to occur.
The humidor has a glass front drawer. Within the drawer back is a dado to hold a foam seal. The drawer front is full overlay. When I make drawers, I usually build a complete box and then affix it to the drawer front. The glass window prohibits this.
I am stuck for an idea on how to attach the “partial box” to the stiles and bottom rail. The drawer isn’t too large or heavy (roughly 13” x 13”x 3”).
Any suggestion will be greatly appreciate.
13 replies so far
View bandit571's profile
bandit571
19144 posts in 2585 days
#1 posted 05-18-2015 05:10 PM
Cut a sliding dovetail for the sides to slide up into.
Is the front Full overlay? Or, just the two sides and the top edges?
Cut the sliding dovetail. Install the sides ( back and bottom can be later) Cut and install the glass and the foam.
Once all assembled, add the two filler pieces to the bottom of the sliding dovetail’s slot. This will close up things nicely. Almost like adding a plug over a counter-bored screw. Mind the grain direction, and the plug will dissappear.
View waho6o9's profile
waho6o9
8097 posts in 2478 days
#2 posted 05-18-2015 05:14 PM
Sliding dove tails.
Dado.
Can you incorporate the bottom shelf into the foam seal dado?
If yes, I would dado and or mortice the box to the back of the drawer with
epoxy.
HTH
View lew's profile
lew
#3 posted 05-18-2015 05:14 PM
I was thinking of that, Steve, but was concerned about the dovetail slot extending thru the bottom edge of the drawer.
It is full overlay on all 4 sides.
bandit571
#4 posted 05-18-2015 05:16 PM
Read on, and find the way to close that slot up.
View Yonak's profile
Yonak
986 posts in 1422 days
#5 posted 05-18-2015 05:25 PM
Additional ideas :
dowel pins
screws from the front if there will be some trim to cover them up
pocket screw on the inside or the outside, then plugged
dowel pin at the top and pocket screw at the bottom (in through the bottom edge)
build all four sides as you normally do but put a view hole in the front piece
waho6o9
#6 posted 05-18-2015 05:29 PM
Maybe threaded inserts and use loctite on the screws
through the front.
Dowel pins are a good idea as well.
View lew's profile
lew
#7 posted 05-18-2015 05:30 PM
Got it, Steve. My old brain just misses about half of what I see.
View BroncoBrian's profile
BroncoBrian
438 posts in 1860 days
#8 posted 05-18-2015 06:27 PM
I think Yonak is right. Dominos would work great for this. #5×3 across the bottom and 2 on each side. Maybe 7 total? It would be easier if holding this in my hands, but I think it would work.
Assuming the sliding dovetail is not an option, that would be the first choice.
-- Bigfoot tries to take pictures of me
View Albert's profile
Albert
499 posts in 3491 days
#9 posted 05-18-2015 06:40 PM
Thinking outside the box: he he
1. make the box
2 attach the front (without the glass opening
3. mill out the glass opening through the front and box at the same time
4. remove the front
5 install the glass
6. reattach the front.
View grizzman's profile
grizzman
7836 posts in 3205 days
#10 posted 05-18-2015 08:42 PM
well im late to the party, looks like its figured out, i was thinking dowel pins and also the threaded inserts, but you got it, cant wait to see it lew….
-- GRIZZMAN ...[''''']
View Roger's profile
Roger
20904 posts in 2705 days
#11 posted 05-19-2015 12:33 PM
Why not pocket holes?
View lew's profile
lew
#12 posted 05-19-2015 12:56 PM
Thanks for all of the suggestions. Sometimes I can’t see the forest for the trees.
The sides/back of the drawer are 3/8” thick so that’s going to limit my options, I think, to dados or dovetails. I like the sliding dovetail idea, now that Steve pointed out the technique of filling the exposed slots. The dovetail should also make a more secure connection, compared to the dado.
I am trying to keep the number of metal objects, inside the humidor, to a bare minimum.
Again, thanks for all of the help. It is truly appreciated.
View mafe's profile
mafe
11631 posts in 2990 days
#13 posted 05-20-2015 09:07 AM
;-) Look forward to see where it ends.
Too late here.
Smiles,
Mads
