Angle on bowls
« back to Scrollsawing forum
Forum topic by KarenMW posted 05-18-2015 02:04 PM 951 views 0 times favorited 5 replies Add to Favorites Watch
View KarenMW's profile
KarenMW
37 posts in 1326 days
05-18-2015 02:04 PM
Topic tags/keywords: question maple oak scroll saw
So I spent time gluing 2 different woods together. A 1/4 in red oak and 3/4 maple. Waited a whole day for the glue to dry and starting scrolling the bowl per the instructions of 20 degrees. After I cut the bottom and the first ring, it did not layer correctly at all. Why are they not laying up? How does one determine what the angle should be?
-- Do not follow where the path may lead. Go instead where there is no path and leave a trail. ~Ralph Waldo Emerson~
5 replies so far
View MrsN's profile
MrsN
987 posts in 3723 days
#1 posted 05-18-2015 02:27 PM
How far off are the rings? bowls are never perfect and always require sanding, sometimes lots of sanding. How thick are the rings you are cutting? To determine the angle you need to know how thick the wood is and how thick your rings are.
Some where I have a chart or something, I’ll see if I can find it.
Katie
KarenMW
#2 posted 05-18-2015 02:35 PM
The wood height is 1in. The ring width is .25 I forgot I had a site http://www.scrollmania.com/ where one can design their own bowls and determine the angle. I was way off! Instead of 20 I should be somewhere around 14. I guess I’ll have to figure out a project to do with the bottom of the bowl that’s already cut. I forgot to measure twice and cut once …..:(
View Al Breit's profile
Al Breit
62 posts in 2090 days
#3 posted 05-18-2015 03:00 PM
Karen Just the thickness of the wood will make a difference as far as the angle goes, the 20 degrees is an approximate. You would need to figure out he correct angle once you know the exact thickness of the wood. You could google trigonometry or figuring out angles and possibly get very close. Hope this helps.
https://www.mathsisfun.com/algebra/trig-solving-triangles.html
-- Al Breit "A day without sawdust is like a day without sunshine"
View MrsN's profile
MrsN
#4 posted 05-18-2015 08:56 PM
The Scroll Mania site is awesome, very good information on cutting the bowls.
You can probably change your angle and do a little more sanding to make the bowl work out.
KarenMW
#5 posted 05-18-2015 09:14 PM
Thank you for all your help.
