Forum topic by SG6578 | posted 05-17-2015 04:04 PM | 745 views | 0 times favorited | 5 replies | ![]() |
I am currently making a coffee table with a thru drawer design and the ends are going to have a floating panel. I routed a groove in the corner posts and frame pieces approx 3/16” from the face. 1/4” slot width. 1/2” deep. Height is 14 3/4” from bottom of the slot to bottom of the slot. I’m looking for values a, b, and c. If you could help me out. I don’t want to run into problems with expansion and cracking. Also, because it’s a floating panel how do you keep it centered? Panel will be solid walnut biscuited together and the frame is solid black ash. |
