Planer kickback
Forum topic by Betsy posted 94 days ago 631 views 0 times favorited 21 replies Add to Favorites Watch
View Betsy's profile
Betsy
2386 posts in 792 days
94 days ago
Topic tags/keywords: planer kick back
I’m now a member of the kick back club, unfortunately. I’m not sure what I did wrong – but this is what happened, maybe some of you can give me some ideas.
I’m planning a 1/2” board (which I’ve done a gazillion times) – just enough to plane off the bandsaw marks from resawing it. So I’m not taking a large cut at all – less than a 32nd (roughly). I place the board on the infeed table, let it engage the roller, held the back up with a finger (not grasping – just holding it up level to the table) – as the board reached the knives – I let got and reached for my next board—- and BAM! The first board shot back and hit me in the elbow. I never stand directly behind any of my equipment when I use it – but this time I had stacked my boards on the wrong side of the planer and had to reach over to get the next board. You can bet I won’t do that again!
I’m not sure what happened – any ideas? The board was perfectly flat on one side, there were no knots or splits (the board was pretty much ready to be used for my project – other than needed resawn.).
As for injuries—- At first I thought I was OK – I’ve got a pretty good scratch where the board bounced off my elbow. But this morning – my arm is really sore and has a clicking noise—- yuck. So tomorrow I’ll call my ortho doctor to see if he can x-ray it for me – I’m thinking I may have chipped it. It doesn’t hurt enough to go the ER and I can move it so I’m not worried about being broken – but if there is a chip I do want to know if I need to have it taken care of.
So guys – what are your thoughts.
View lew's profile
lew
4490 posts in 651 days
94 days ago
Wow, Betsy!
Hope it isn’t any thing serious!
I have had boards shatter because of knots or splits but never like what you described.
The only thing I can think might have happened is that the side you were planing may not have been parallel to the opposite side. Maybe after the board engaged the knives, it lost contact with the infeed roller and there wasn’t enough pressure to hold it with the outfeed roller and it got kicked back.
Home the x-ray shows no damage.
Lew
16910 posts in 473 days
94 days ago
Hey Betsy
Usually kick back occurs when your planning two boards at one or to short of wood . I could only guess the feed rollers are not level. I think Lew’s explanation is possible also.
Betsy
94 days ago
Lew – you might be onto something there. Since this was a resawn board – the sides may not have been perfectly parallel. I just looked at some of the other boards that I have not yet planned – and there is a slight difference between them. With that said – the face that was on the table was flat – but the resawn side did have some thickness difference. So I do know that I had good contact with the table. I think I’ll take a hand plane to get them cleaned up – sure would be safer.
Jim – length is definitely not it this time – the boards were all about 3 feet long and I was only feeding one at a time. But that does bring up a good point to others – anything less than a foot should not be run through a planer without a carriage.
As for the rollers – I think you have brought up another good point – I’ll check those this afternoon.
Thanks for the input guys.
View Chris 's profile
Chris
1469 posts in 887 days
94 days ago
Betsy,
What kind of planer is it?
-- Chris
Betsy
94 days ago
DeWalt bench top – model 733
Todd A. Clippinger
5648 posts in 995 days
94 days ago
That is a good planer.
My thoughts were the same as Lew’s because I have had a near kickback experience with my own resawn material and that was the issue.
Betsy
94 days ago
Thanks Todd. The more I think on it, the more I think Lew is right.
Chris
94 days ago
I’ve planed a fair amount of re-sawn material; How far out of parallel would the two sides have to be? Like Betsy I have never seen this before.
-- Chris
View Greg Wurst's profile
Greg Wurst
716 posts in 728 days
94 days ago
Eek! I plane resawn boards with my 733 and never think about kickback. I’ll definitely have to stay away from the business end in the future.
View woodisit's profile
woodisit
61 posts in 138 days
94 days ago
Hope your ok. I agree with Lew but you might also check alignment your in feed and out feed tables. I had trouble with my 733
-- Woodisit
Betsy
94 days ago
I think its never a good idea to stand directly behind our machines – as this has proven – you never know when the machine will chuck something back at you.
I’ve checked my planer and the rollers seem to be OK as is the alignment of the in feed and out feed tables. I really think my problem came down to the difference in the parallel of my resawn material. Either way——it hurt!
Thanks for the help guys.
Be safe out there!
View tooldad's profile
tooldad
454 posts in 611 days
94 days ago
I have had that happen on a drum sander. However I was sending 2 4” boards through at the same time and one was a little thinner than the other. Both were 3/4” stock from HD, but not exactly the same I guess. It shot one of them fortunately towards the outfeed side. Did this twice and that was enough. AFter that only sent one through at a time.
View Mark Mazzo's profile
Mark Mazzo
343 posts in 808 days
93 days ago
Betsy,
Sorry to hear about your kickback. I hope that your injury is not serious.
In my experience, the other posters have touched on the usual problems (boards too short, or two boards not the same height). Lew brought up a good point in that if your re-sawed material has a major dip in it such that the rollers loose contact with the material and th knives catch it, it will kick back!
Given what you’ve stated, that is the only possibility that i cam come up with.
View PurpLev's profile
PurpLev
2759 posts in 544 days
93 days ago
Betsy – thanks for bringing this up. with lew’s and others’ responses, it’s something worth thinking about when sending material through the planer, that many of us (aka me) wouldn’t think about if not told of the possibility.
anything safety wise is welcome.
hope the doctor doesn’t find anything serious, and things heal quickly.
View Walnut_Weasel's profile
Walnut_Weasel
246 posts in 118 days
93 days ago
Thanks for sharing. I hope I can remember this when I get around to purchasing a planer one of these years! I wonder if there could be an easy way to install anti-kickback wheels that are typically used for table saws onto a planer for an added level of safety…
-- James - What's your excuse this time??
View hairy's profile
hairy
294 posts in 428 days
93 days ago
Just a thought: Were you feeding with or against the grain?
Scars are good for bragging rights. Glad you’re ok.
-- I'm a lumberjock and I'm ok, I sleep all night and I work all day!
View juniorjock's profile
juniorjock
790 posts in 661 days
86 days ago
After reading this, I’m just wondering how common this is. Anyone else had kickback while using a planer? ........ Been and week now, feeling any better Betsy?
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
Betsy
85 days ago
JJ – I can’t say that I’ve ever really heard of planer kickback before this happened to me. So I don’t think it’s that common. Still – it’s a good idea not to stand directly behind the thing while it’s running!
As for my arm – seems I have a bone bruise. So no chips or anything. May take 3 or 4 months for the bruise to go away but that’s OK. Thanks for asking.
juniorjock
85 days ago
Ouch! I hope you get better soon. But your accident sure opened my eyes! The only thing I ever think about when I’m running my planer is catching the board when it comes out the other side. Just one of those things….. you learn and we all learn. You just learned a little harder than the rest of us. Be safe!
View gagewestern's profile
gagewestern
145 posts in 246 days
77 days ago
the board that kicked back on me had a small dip in the middle . i reached for another pice just befor it got to that point bamb! 6 stiches in my thumb. like most i stand to the side of all tools but that stil leaves your hands. brian
-- gagewestern
View reggiek's profile
reggiek
712 posts in 166 days
77 days ago
Glad to hear you were not seriously injured!...and it is definitely a wake up call…I use a Grizzly G0454 planer which is 5hp and can really kick a board hard….I have been diligent in not standing behind my feeds on any saws…and now I will make sure of the planer also. I always wear a pair of good welder’s gloves when feeding stuff into any machine as I once caught my hand with a splinter…when I involuntarily jumped from the surprise…I pulled the board towards the blade and it shot out with enough velocity to do some serious damage…luckily for me that no one including myself was in its path.
Always remember to work safe….its never worth an injury to get something done quicker…..After years in contracting and dealing with safety/osha….it is an ingrained procedure for me…I force myself to leave the shop if I find myself not keeping up with safety…you should always review your procedures both before and after using any tool. This reinforces safety – it is what we teach in our safety meetings every morning prior to moving out on the job.
Keep Safe.
