Ceramic guides falling out of Laguna 14 twelve
Forum topic by Drew posted 05-16-2015 08:22 PM 4734 views 0 times favorited 21 replies Add to Favorites Watch
View Drew's profile
Drew
336 posts in 2970 days
05-16-2015 08:22 PM
Like the title says…
Two of the guides fell out of the lower guide block assembly today. Of course Laguna won’t answer a phone call on a Saturday…. if at all…
Has this happened to anyone else? If so what was your fix?
I thought about using epoxy to put them back in but was worried about replacing them in the future.
What are your thoughts?
Thanks in advance
-- TruCraftFurniture.com
21 replies so far
View Ghidrah's profile
Ghidrah
667 posts in 1092 days
#1 posted 05-16-2015 08:43 PM
I’m not sure I understand correctly, are you talking bearings or cool blocks?
-- I meant to do that!
View Drew's profile
Drew
#2 posted 05-16-2015 08:59 PM
The 14 twelve uses ceramic guide blocks
Similar to this…
Ghidrah
#3 posted 05-16-2015 09:47 PM
I pulled up the Laguna manual, the image they show for the lower block, (pg 35) looks similar but I found no instruction for changing the ceramic, only that they must be just behind the gullet. without actually removing the block and disassembling it I’m guessing the ceramics are the dark grey 1/2 circles and sit inside the half round rings either side of the band. Is it possible the side guide screws got loose, pulled away from the band enough to fall out?
View Drew's profile
Drew
#4 posted 05-16-2015 10:18 PM
The little white pieces in the picture above are the ceramic guides.
2 of those have fallen out.
Ghidrah
#5 posted 05-17-2015 12:18 AM
?I knew that, ... I was just testing you┬┐ Well then I’m even more confused. So what’s the grey thing in the middle? Can you pull the white things out without fuss? Do they shoot out the front of the block during use? Are there no covers? The 14/12 manual does not show the view you have above, looks like covers held in place by 2 knobs.
Sorry can’t help here my SF 1707 used bearings
At the risk of never getting them out I wouldn’t attempt to glue them in. I would hold off till I got a hold of Laguna and got some kind of answer.
View Aj2's profile
Aj2
1222 posts in 1668 days
#6 posted 05-17-2015 04:32 AM
I had a 16 inch laguna saw with the ceramic guides.I used 5min epoxy to glue the ceramic back in.I used to clean them up off the saw and tru up the faces that touch the blade after while they pick up the metal from the sides ot the blade.And turn gray.Aj
-- Aj
View AlaskaGuy's profile
AlaskaGuy
3756 posts in 2179 days
#7 posted 05-17-2015 04:44 AM
If you epoxy them in how do you replace when they wear out. I assume they wear out.
MrUnix
6186 posts in 2069 days
#8 posted 05-17-2015 05:20 AM
They are held in place from the factory using gel super glue. I wouldn’t use epoxy.
PS: Here is the video on replacing the guides:
http://www.dailymotion.com/video/xpyikh_laguna-tools-hd-bandsaw-replacing-ceramic-guides_tech
Ghidrah
#9 posted 05-17-2015 02:23 PM
Rough idea on how often the guides need to be replaced? Can the saws be refit with guide bearings?
View Aj2's profile
Aj2
#10 posted 05-17-2015 02:58 PM
When the guides wear out you’ll have to buy a new saw. Come on guys…
-- Aj
View Drew's profile
Drew
#11 posted 05-17-2015 03:41 PM
Excellent information jocks! Thank you!
View AHuxley's profile
AHuxley
652 posts in 3191 days
#12 posted 05-17-2015 05:31 PM
- Ghidrah
It is very hard to answer that question since there is no way to account for all the varied conditions different users subject them to. Suffice it to say they last a very long time in “normal conditions”. Stoning the back of the blade helps keep the thrust “bearing” from excessive wear, most people seem to find they are the first one to go. IIRC the cost of a set of inserts is about $80 and will outlast the standard small bearings on most current bearing type guides by many times and will likely be more cost effective than bearings (again small bearings) even using the large number of cheap bearings out there. The Laguna (and Felder) ceramic guides tend to be a love ‘em or hate ‘em sort of product, I find their positives significantly outweigh their negatives is most situations.
AHuxley
#13 posted 05-17-2015 10:20 PM
- Ghidrah
After reading that you have Timberwolf bandsaw blades for half a decade that aren’t worn out I would say at that rate of use you would be unlikely to ever wear a set out… :)
View FlyinWillys's profile
FlyinWillys
23 posts in 477 days
#14 posted 04-25-2017 05:11 AM
I detest the ceramic guides. Can’t keep them from falling out or adjusted. Very hard to reach the lower block to adjust, almost need to take the top off to get at them. I love the saw but would much rather have the bearings!
-- Old retired guy!
FlyinWillys
#15 posted 04-25-2017 05:16 AM
-- Old retired guy!
