Please help with Mortise & Dowel hole jig review !
« back to Joinery forum
Forum topic by usmcshooter posted 05-16-2015 07:19 PM 1136 views 0 times favorited 3 replies Add to Favorites Watch
View usmcshooter's profile
usmcshooter
18 posts in 2001 days
05-16-2015 07:19 PM
I hoped to get some takers, or questions asked on my post from 02.36PM 5/15/15. We are interested in demonstrating, and letting folks use a new mortise and dowel hole jig, for response and interest to help with how well it will be received in the market place, within 300 miles of Austin / San Antonio TX, or more if necessary ?? Anyone interested ?
There are no wood shows to go to, to demonstrate this jig, so we are looking for individuals, a wood working club, or group of woodworkers to demonstrate it to, and let them use, for feed back. No cost or obligation. If you don’t do much dowel or mortise and loose tenon joinery because of difficult setup, inaccurate holes and non-repeatable production, this jig will make you go WOW !! Please respond so we may help you with your projects !!
Here is a 3 minute video making 8 dowel holes accurately for a small picture frame, AND inserting dowels with assembly in real time. To do mortises with loose tenons you just route out the distance between the holes. You can switch from doing mortises to dowel holes, just by changing your mind. Do 45 degree corners just as easy. Set up is very easy as well, and you can go from 1/4” stock to 6” in less than a minute or two. VERY accurate and repeatable.
https://www.youtube.com/watch?v=NshPztTZevM
-- "It's always too soon to quit"
3 replies so far
View cabmaker's profile
cabmaker
1744 posts in 3046 days
#1 posted 05-16-2015 08:01 PM
Looks like it may have some potential
How is it for mortise setups…..time wise ?
I would be willing to take it for a spin but quite honestly I think it would slow me down…..can’t tell without using it a bit
I’m in your distance criteria,....just pm and let me know
Thanks
View lcurrent's profile
lcurrent
125 posts in 4052 days
#2 posted 05-16-2015 08:42 PM
I have seen it working set up takes from one size to another about 3 min from say 1/2 to 1 in then repeat cuts take about the the time for the router to wind down and they are all in the same place it takes longer to mark the center of the cuts than it does to cut them
-- lcurrent ( It's not a mistake till you run out of wood )
View Arlin Eastman's profile
Arlin Eastman
4258 posts in 2798 days
#3 posted 05-17-2015 06:03 PM
To me it is not about how much time it take to set up but how easy it is to use and how good it does.
-- It is always the right time, to do the right thing.
