Biscuits
Forum topic by Don Newton posted 08-22-2009 08:59 PM 1025 views 0 times favorited 7 replies Add to Favorites Watch
View Don Newton's profile
Don Newton
716 posts in 3618 days
08-22-2009 08:59 PM
Topic tags/keywords: biscuits
Well Lumberjocks…..It appears as though my biscuits have swelled! Sounds painful but I can assure it is only annoying. I guess the plastic bag I had them stored in wasn’t good enough. I read somewhere that you can put them in a microwave to dry them out. Has anyone tried that, or have a better idea? How do you store yours?
-- Don, Pittsburgh
7 replies so far
View Dan'um Style's profile
Dan'um Style
14172 posts in 3983 days
#1 posted 08-22-2009 09:06 PM
micro wave should work … also your oven and bbq
View FirehouseWoodworking's profile
706 posts in 3273 days
#2 posted 08-22-2009 09:21 PM
Either microwave or an over. I store my biscuits in clean peanut butter jars. They hold quite a bit and are air tight, which keeps the moisture out.
-- Dave; Lansing, Kansas
117091 posts in 3577 days
#3 posted 08-22-2009 09:23 PM
The oven and a little Jam MMMM
View LesB's profile
LesB
1728 posts in 3443 days
#4 posted 08-22-2009 09:32 PM
When the biscuits are made they are compressed so they will expand in the joint. Moisture causes them to expand. Therefore they work best with water based CVA glues and not urethane or super glue.
Drying them out may help if they did not absorb too much moisture but it will not completely shrink them so make sure they fit in you slots before you use them and have a jam up.
I would buy a new batch and make sure they are stored in a moisture proof container. I use a large plastic jar with a tight fitting lid.
-- Les B, Oregon
View scrappy's profile
scrappy
3507 posts in 3430 days
#5 posted 08-23-2009 03:54 AM
Here is a link on how to dry wood in the microwave.
http://www.woodisfun.com/microwavedrying.html
Used it on some coasters about 3 months ago and they never cracked, so must have dried good.
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View LesB's profile
LesB
#6 posted 08-23-2009 09:04 PM
Scrappy,
Microwave drying works great, I use it all the time to speed up the drying process when turning wet wood. In this case I think the biggest problem is that the factory process of making the biscuits intentionally compresses the wood so it will expand and firmly fill the slot when a moist glue is used. Therefore once biscuits have expanded from moisture, regardless of the source, it is all but impossible to re-compress them. On one occasion when it happened to me I just died them and sand them down a little to fit the slots; however that defeats the expansion process and could produce a weaker joint.
-- Les B, Oregon
View RBWoodworker's profile
RBWoodworker
441 posts in 3352 days
#7 posted 08-23-2009 09:16 PM
I had this happen to me and I simply took a hammer and gently tapped and flattened them down..it was fast, quick and did the job fine.. I don’t have a microwave at my shop..so it was the only solution at the time..still..it worked good..lol
-- Randall Child http://www.racfurniture.com/
