Home Made Pocket Hole Plugs
Forum topic by wdkits1 posted 97 days ago 553 views 0 times favorited 8 replies Add to Favorites Watch
View wdkits1's profile
wdkits1
95 posts in 251 days
97 days ago
Hi everyone
l love using pocket hole screws. They are quick, easy to use and make a strong connection. The down side is that you normally can’t use them for exposed work mostly because they are kind of ugly.
Well on the latest project that I’m working on (custom closets) there are a few places that I have to use them in an exposed area so I had to figure out a way to make plugs (out of Jatoba) to fill in those ugly holes. Here is what I came up with.
I start by turning a 3/8” dowel out of 1/2” scrap. I use a 3/8” open end wrench as a reference to get the dowel to uniform size.
Next step is to drill a pocket hole (with Kreg Jig) in a scrap piece of wood and insert a screw( to drive out the cut plug).
Insert the dowel into the pocket hole until it bottoms out against the screw head.
Set the fence on the bandsaw to just clear the edge of the dowel jig and saw off the dowel.
I use a belt sander to sand the plug flush with the jig and pop it out with the exposed screw.
Here is the installed plug in place on the bottom shelf of the cabinet.
Hope some of you can use this little tid-bit of info.
-- Mike www.midlothianwoodworks.com
17022 posts in 475 days
97 days ago
Hey Mike
Thanks for sharing,cool idea.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
20754 posts in 720 days
97 days ago
Mike, that is a novel approach. I know that you can buy the plugs but they are limited as far as the wood species goes. Like you I enjoy using pocket screws, especially in cabinet construction but have never used them on the exposed faces simply due to the problem that you described. This approach certainly gives me something to consider.
Thanks for the post.
25806 posts in 1298 days
97 days ago
I bought a bit that goes in my drill press and it cuts plugs from what ever wood you want. I think it was Rockler that made it. I’ve never used it yet. (now I need to go and find it)
View Chris Wright's profile
Chris Wright
360 posts in 379 days
97 days ago
Here’s a nice plug cutter that you can use to cut plugs at an angle and really conceal the holes.
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=151-439
-- "At its best, life is completely unpredictable." - Christopher Walken
View drgoodwood's profile
drgoodwood
387 posts in 1025 days
97 days ago
A Japanese Flush Cut saw also works.
Lee Valley
-- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower."
View Joe Weaver's profile
Joe Weaver
109 posts in 584 days
97 days ago
I got a tenon cutter 3/8 from mlcs and make all my own plugs.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/plgtenon.html
-- Joe, Ga
View spanky46's profile
spanky46
737 posts in 288 days
97 days ago
Great ingenuity Mike! Thanks for sharing.
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
wdkits1
97 days ago
That is what I find fun about woodworking .Making chicken salad out of chicken s—t. LOL
