Gap Filling Miter Joints - Another Alternative?
Forum topic by DeLayne Peck posted 05-16-2015 12:18 AM 1702 views 0 times favorited 9 replies Add to Favorites Watch
View DeLayne Peck's profile
DeLayne Peck
480 posts in 2077 days
05-16-2015 12:18 AM
Topic tags/keywords: trick oak tablesaw sand paper chisel utility knife shaping joining
Nothing is more irksome than a open miter. And, I was certainly irked with the my miters on a mirror frame for medicine cabinet I am building in red oak. There were small, but glaring gaps. After reading all the LJs advice, I decided to experiment:
1. I cut a 1/16” shim in red oak.
2. The shim was sanded on one edge to 1/64” to form a wedge. The gap was carefully opened further with a utility knife to create a uniform gap. The wedge was tapped in into the gap.
3. The wedge was cut down and sanded flat.
4. On another corner, I used more than on wedge.
Speculation: Should stain well. No glue involved. Decent result, the gaps can escape notice.
What say you?
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
9 replies so far
View Snowbeast's profile
Snowbeast
76 posts in 1213 days
#1 posted 05-16-2015 12:25 AM
Looks to me like it will work. I’ll have to remember this since I end up with the same type gaps.
Thanx, DJ
Gerald Thompson
855 posts in 2110 days
#2 posted 05-16-2015 12:30 AM
I fixed that problem with miters. Made two shooting boards. One a 90d and the other at 45d. I use the LV LA Jack. I use my miter saw to cut to 45d and then use the shooting board. One has to count the passes to make sure all are cut the same. The miters almost disappear.
-- Jerry
View BurlyBob's profile
BurlyBob
5151 posts in 2141 days
#3 posted 05-16-2015 01:16 AM
Looks like you really nailed it. If you don’t mind I’m going to remember and use that trick. Thanks.
View bonesbr549's profile
bonesbr549
1469 posts in 2942 days
#4 posted 05-16-2015 12:46 PM
Shims work great and used them before. When the gap is on the end I’ve used the router bit trick to roll the edges over.
Now, I use Incra with vernier scale and If I’m off by a hair, I can just adjust my cut angle by a hair, and bring it in. I’mean in the end, if you have one side of that miter, at 45.6, and the other at 44.4, no one will know.
I seen this when I’m doing trim on a piece and it’s not perfect at 90.
View ChipByrd's profile
ChipByrd
146 posts in 1802 days
#5 posted 05-16-2015 01:20 PM
That will be very helpful in the future!
I have been woodworking for about 3 years or so, and it’s interesting that one of the truly challenging tasks is to make perfect miters (at least larger ones). I did make a sled for my table saw and that has been super handy.
View Roger's profile
Roger
20898 posts in 2679 days
#6 posted 05-16-2015 01:34 PM
You’ve done a fine job of fixin.
View RogerM's profile
RogerM
786 posts in 2274 days
#7 posted 05-16-2015 01:38 PM
The difference between a master craftsman and a novice is that the master knows how to hide his mistakes better. You are definitely the master on this one. Thanks for sharing.
-- Roger M, Aiken, SC
RogerM
#8 posted 05-16-2015 01:38 PM
View distrbd's profile
distrbd
2252 posts in 2322 days
#9 posted 05-16-2015 02:21 PM
As long as it’s not noticeable when you stain it, it is a great fix .
-- Ken from Ontario, Canada
