Glue lines telegraphing through paint? Cold creep? HELP!
Forum topic by JayPique posted 08-21-2009 05:33 PM 1286 views 0 times favorited 4 replies Add to Favorites Watch
View JayPique's profile
JayPique
61 posts in 3254 days
08-21-2009 05:33 PM
I recently came into a bunch of 4/4 rough maple and would like to laminate some of it into thicker stock for legs. I’m planning on either painting or ebonizing them, so I’m not so worried about grain or color match as I am about the glue lines becoming visible over time. (Is this called “cold creep”?) I’ve seen where even T3 develps this and I’d like to avoid it if possible. Can anyone recommend a glue that would minimize this issue?
Thanks.
JP
View Sam Yerardi's profile
Sam Yerardi
244 posts in 3861 days
#1 posted 08-21-2009 06:42 PM
You might consider hide glue. I don’t have any experience with it in terms of your application (painting) but I know a lot of manufacturers of the years have used it successfully. In terms of using it with any other type of finishes I’ve had very good success.
-- Sam
View Roper's profile
Roper
1389 posts in 3679 days
#2 posted 08-21-2009 07:55 PM
i’m not really that sure about the glue, but a coat of shellac inbetween the wood and paint might help to keep the glue from moving.
-- Roper - Master of sawdust- www.roperwoodturning.com
View pommy's profile
pommy
1697 posts in 3657 days
#3 posted 08-21-2009 09:26 PM
Have you thought about epoxy we use it all the time never had a problem yet …...........
Andy
-- cut it saw it scrap it SKPE: ANDREW.CARTER69
117063 posts in 3543 days
#4 posted 08-22-2009 04:13 AM
Resin glue
