Preping Reclaimed Lumber
Forum topic by johnnymo posted 99 days ago 336 views 0 times favorited 12 replies Add to Favorites Watch
View johnnymo's profile
johnnymo
70 posts in 104 days
99 days ago
Topic tags/keywords: pine planer
I have a lot of reclaimed wood that I would like to plane. I know I need to get a metal detector for finding nails and screws but what about the grit that is on the wood? I recently purchased a Jet 10” jointer/planer combo and I don’t want to mess up the knives on it. Can I go ahead and start planing the wood (I think it’s pine) or do I need to sand the grit off the wood first before planing.
-- John in Arizona (but it's a dry heat!)
View PurpLev's profile
PurpLev
2763 posts in 547 days
99 days ago
what is this “grit” – if this is goo, I would use an angle grinder with some wheel brushes and clean it off, or use some chemical that will desolve it, and then wipe it off, otherwise it WILL gum up your planer/joiner knives real fast – like – REAL fast
I just used reclaimed bowling alley lanes to build a workbench, and I used a wheel brush to take off the tar and finish that was on the floor slabs before jointing/planing/routing the material. before I did that – I tried hand planing it off, but it completely marred, and gummed my hand plane after a few strokes to the point it wouldn’t cut through anymore.
johnnymo
99 days ago
The grit is mostly dirt. The wood was used to hold metal tubes, bars, and sheetmetal together on pallets so there is some type of lubricant on some of these. I did do some sanding and the wood looks good underneath. I was wondering, to save time, if I could just run the wood through the planer?
View MedicKen's profile
MedicKen
482 posts in 360 days
99 days ago
I would use a good stiff wire brush and remove as much of the grit and dirt as possible. If you have an “old” set of knives I would use those first and then change blades when you get the initial pass done for final thicknessing.
2458 posts in 239 days
99 days ago
some comercial shops will plane boards ,
for a fee , and they use old blades to do it ,
if you want to do it yourself ,
get another set of knives ,
and run the ones you got already in the machine.
View john's profile
john
1196 posts in 1280 days
99 days ago
I use reclaimed wood everyday so i decided the easiest and fastest way to clean up recycled wood is with a cheap planer and cheap blades . I scrape off as much crap as i can with a scraper and that’s it .
-- John in Belgrave ,(Slideshow http://cid-69bce320c6d8b119.spaces.live.com/ (Website) http://www.extremebirdhouse.com
View Mike Gager's profile
Mike Gager
229 posts in 165 days
99 days ago
how about a belt sander?
View TheWingDoctor's profile
TheWingDoctor
13 posts in 341 days
99 days ago
The junk on these boards will destroy your planer/jointer knives in a heartbeat, and then you do not have a way to get a good finished surface without replacing the blades. I watched Norm :) do this, and I have used it also with good results, use a metal detector or a sharp eye to remove all the metal and then remove the surface junk with a course belt on a portable belt sander. The grit and and other junk will not hurt the sanding belt like it will those expensive planer blades. Once you have the wood as clean as you can get it run it through the jointer and the planer to bring the surface true.
Saving money is great, but save those planer blades too!
Bruce
-- Bruce - Fav. Quote "A man's got to know his limitations." Dirty Harry Calahan
View Julian's profile
Julian
695 posts in 423 days
97 days ago
I like to use my drum sander with 80 grit on it to remove the dirty outer layer when using reclaimed lumber. If you don’t have a drum sander I recommend using a beltsander as was previously stated.
-- Julian, Park Forest, IL
Beginningwoodworker
4217 posts in 571 days
97 days ago
You might wont to clean the lumber up before you run it though the planer.
-- CJIII Future cabinetmaker
View DaleM's profile
DaleM
417 posts in 282 days
97 days ago
I just used a wire brush, followed by a quick once over with an old paintbrush to remove dirt on old lumber and my planer blades held up pretty well. Well, they did, until one particular board. It had a lot of old nail holes, but no nails/metal. I cleaned it up some and ran it through and that was the end of useful life for my blades. Someone had apparently used the board as a form for pouring concrete at one time and some of the nail holes had filled up with concrete. One in a million chance that would happen I guess. Just use common sense and be careful and realize any grit left on the wood is going to have some affect on the blade, however small, so it will dull it faster than perfectly clean wood. If there is an oily buildup, use a scraper as someone mentioned above.
-- Dale Manning, Carthage, NY
johnnymo
97 days ago
Wow! Thanks for all the suggestions. A lot of great ideas here. Again, thanks! Keep the ideas coming!
View Chris Wright's profile
Chris Wright
360 posts in 379 days
97 days ago
You could always just hose them down real well. If you have a pressure washer that would take it off. Then you let it dry real well before you plane it.
-- "At its best, life is completely unpredictable." - Christopher Walken
