chair back and seat angles
Forum topic by daddywoofdawg posted 05-14-2015 11:51 PM 765 views 0 times favorited 6 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1809 days
05-14-2015 11:51 PM
I found a photo of a chair I would like to try to make but it’s just a photo.trying to figure out a starting point for the chair back and seat angles. 0 being horizontal,90 being vertical.also seat and arm heights.what numbers would you start at?this will be my first from scratch chair and need some starting points.
View Beams37's profile
Beams37
166 posts in 1424 days
#1 posted 05-15-2015 12:11 AM
70?
-- FNG ... On a quest for knowledge.
daddywoofdawg
#2 posted 05-15-2015 01:22 AM
70? what the back?
19579 posts in 2091 days
#3 posted 05-15-2015 01:33 AM
The back looks to be around 110 – 120° if horizontal is 0 and the seat about 10°. I would try setting up some boards however you can to see what feels comfortable. Arms appear to be level.
View mahdee's profile
mahdee
4041 posts in 2002 days
#4 posted 05-15-2015 02:03 AM
Back looks like 22 degrees. Seat should be about 16-17” from the floor. Arms are at 90 degrees and about 23” from floor. In the pictures, the arms look too high. I would connect the seat and the back first. Have to cut a dado at 22 degrees and insert and glue the seat/back and build the frame around it.
-- earthartandfoods.com
mahdee
#5 posted 05-15-2015 02:05 AM
Actually, the seat looks like is at 5 degree as well.
View crank49's profile
crank49
4032 posts in 3205 days
#6 posted 05-15-2015 02:47 AM
I’d try something that wasn’t so butt ugly.
