Up Spiral Bit or Down Spiral Bit?
Forum topic by Nicholas Dillon posted 95 days ago 298 views 0 times favorited 5 replies Add to Favorites Watch
View Nicholas Dillon's profile
Nicholas Dillon
12 posts in 126 days
95 days ago
Soon i will be starting a garden bench project that requires some mortise and tennon joints. I could do them by hand but I have a lot to do. I do not have a plunge router.
I want to use my router table and need to know whether I need to use a down or up spiral bit when lowering the wood down onto the router bit. Thanks
-- My workshop is a 8 x 8 shed! No Joke!
View PurpLev's profile (online now)
PurpLev
2745 posts in 543 days
95 days ago
up to pull the shavings UP from the mortise towards the router (and since it’s upside doen, it means = down to the floor)
teenagewoodworker
2481 posts in 662 days
95 days ago
upcut…. both for handheld and router table… not gonna make it any more confusing than that
View CessnaPilotBarry's profile
CessnaPilotBarry
1265 posts in 597 days
95 days ago
Up, to clear the chips towards the bit shank from the fully housed hole being cut. There might be a small amount of tearout around the hole, but nothing that will compromise the joint or show after assembly.
Down spirals are used when you want the cleanest edge closest to the bit shank, especially in veneered stock and plywood, but have somewhere for the chips to go. For instance, edge routing or a through mortise.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View DaleM's profile
DaleM
409 posts in 278 days
95 days ago
Okay, I know this is the exact opposite of what everyone just said, but I use the down spiral bit for mortises, to get the clean edge as noted above. Some of the shavings do tend to build up in the hole sometime, but no worse than a straight bit, at least in my experience. Of course, if you weren’t using a table, just the router, you would need the up spiral or your mortise would really fill up with shavings. Either one gives a cleaner cut than any straight bit I’ve tried.
-- Dale Manning, Carthage, NY
View Mark Mazzo's profile
Mark Mazzo
343 posts in 807 days
95 days ago
For the reasons stated, use an upcut bit for mortises to eject the chips more efficiently when the mortise is being cut.
The only time you need to use a doowncut bit is if you need a very cleanly cut opening such as on a through mortise or when inlaying one piece into another.
On the standard mortise, the mortise is covered by the piece with the tenon so using the upcut bit trades off the efficiency of chip ejection and ease of cutting for possible tearout at the surface (which still almost will never happen with an upcut bit)
