Question about festool rails, join two 55" rails or order the 106" rail?
Forum topic by kennymac posted 05-14-2015 01:41 AM 2354 views 0 times favorited 20 replies Add to Favorites Watch
View kennymac's profile
kennymac
41 posts in 1231 days
05-14-2015 01:41 AM
Topic tags/keywords: miter saw jig
Been meaning to post here more, just no spare time between work and the damn yard work. I love spring but it certainly brings me a lot of work. Okay, on to my question…
I just ordered the TS55 with one of their vacuums, and it came with the 55” rail. Looks nice, haven’t had a chance to put it to use yet (the front yard is starting to really look good though) but I’ve got plans for the saw once I really get some shop time. One of my goals this summer is to get some cabinets built for our walk in closet, along with some shop cabinets, and I will need to be able to cut out pieces anywhere from 60” right up to a full 8’ sheet of plywood. Looking at the rails online the price of the 106” rail is over $300 without shipping whereas the 55” rail is only $130. One would assume that joining the two 55” rails would yield me the length I need to tackle any cut, however I am not sure if joining rails would compromise the quality of the cut.
So I am asking those of you with experience with the festool rails, would joining the two 55” rails be as secure and clean a cut as using a 106” rail? Or would there always be an apparent defect when cutting with the two rails joined?
Just a side note, I have two thin flimsy aluminum rails that join together with a small plate with two screws. Last time I used it with my circular saw to cut a full size sheet of 3/4 birch plywood the cut had a big bow in the middle, leaving the cut with a slight curve. Practically a waste of a sheet of plywood had it been anything but a shop table top I was cutting. I’m of the mind that I’d rather spend a little more $$ up front to ensure I have a reliable tool then have to fix this again.
Thanks in advance for any help.
20 replies so far
View BroncoBrian's profile
BroncoBrian
542 posts in 1984 days
#1 posted 05-14-2015 01:53 AM
https://www.youtube.com/watch?v=pVFuPfvhHfE
Combine them, you will be glad to not store the 106” when you rarely need it.
-- I think foosball is a combination of soccer and shish kabobs.
View Mike Throckmorton's profile
Mike Throckmorton
124 posts in 1690 days
#2 posted 05-14-2015 02:34 AM
It is very difficult to get the two joined rails straight and then hard to keep them straight for multiple long cuts.
If you plan on using the tool more than a little for longer cuts (and you have the money) buy the longer rail.
The cleats on the garage door storage method works great
-- You are never complete, you just draw a line where done is and stop at that line.
View timbertailor's profile
timbertailor
1594 posts in 1450 days
#3 posted 05-14-2015 03:11 AM
- Mike Throckmorton
+1
Really need to buy one of each, I am afraid.
View waho6o9's profile
waho6o9
8207 posts in 2603 days
#4 posted 05-14-2015 03:38 AM
To prevent that middle bow I put a stopper in the center and it
helps a lot.
Connecting to rails works well, just be patient.
kennymac
#5 posted 05-14-2015 04:06 AM
Thanks for the tips so far. I’m not sure I understand the need for the stopper to help prevent the bowing, my understanding is that the rails are quite good at staying in place once there down on the board being cut. Plus I wasn’t aware that you need to put any pressure on the saw to keep in snug against the rail.
So two recommend joining rails and two say it’s worth getting the longer, anyone else?
4999 posts in 2519 days
#6 posted 05-14-2015 11:18 AM
I bought 2 55” rails and thought it was the cat’s arse. I was wrong, joining them to be perfectly straight was simply a PITA (and never worked either). If I was doing it over I would go straight to the 106”, which is really useful for straight edging rough sawn lumber as well as the long dimension on sheet stock. If you have to have 2 shorter ones, I would choose a 55” plus a 75”; much more versatile. Storing the 106 wasn’t that hard for me. I screwed the shipping crate to the ceiling and put it there.
View TREV0R's profile
TREV0R
1 post in 1134 days
#7 posted 05-14-2015 12:28 PM
I own the 106 and two of the 55 rails. I find that joining the rails together works as well as the long rail. And a tip for joining the 55’s together. Tighten the two cambered adjustment screws on the base of the TS 55 so there is no slop when the saw is on the track, then use the saw itself as the straight edge. Set the saw so it overlaps the tracks where they will be connected. Just make sure to connect the bottom side of the tracks first. Then use the saw as the final adjustment on the top side.
View JoeinGa's profile
JoeinGa
7736 posts in 2033 days
#8 posted 05-14-2015 10:30 PM
Here’s something else to consider …
What are the chances that UPS or FedEx will deliver that 8foot+ long package to you and it has NOT been bent in half?
#9 posted 05-15-2015 11:07 AM
I can only say that mine arrived in good shape, the Festool crate is somewhat substantial. I believe (but do not remember) it was delivered by Fedex. But your point is valid.
kennymac
#10 posted 05-17-2015 01:33 AM
Thanks again for the replies and advice. I’m down in Tampa for the weekend helping my mom celebrate her 80th birthday so it’s been hard to keep up with this thread.
I ordered the 106” rail yesterday though Amazon. Shipping was free and they actually scheduled delivery next Wednesday. I probably could have gotten away with joining two rails, but it seems that the one long is a sure bet to get the job done right. I’ll try to report back once I have it and give a brief review.
Thanks again everyone.
View AlaskaGuy's profile (online now)
AlaskaGuy
4207 posts in 2335 days
#11 posted 05-17-2015 01:58 AM
Everyone knows that when you joint two rails they don’t touch each other, you leave a small gap between them right?
View zzzzdoc's profile
zzzzdoc
550 posts in 3029 days
#12 posted 05-17-2015 12:17 PM
I never could get two joined rails to be perfectly straight, so like you I ordered the longer rail. Happy with my decision.
OK, I’ll bit. Why do you leave a small gap between the rails?
-- Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
#13 posted 05-17-2015 12:42 PM
I’m not sure of the reason, but Festool suggests leaving a gap (it was in a picture on the box of my shorter rails). I can only speculate that the ends may not be a perfect 90ยบ, but other than that I’m not sure why that’s so important….but it is what Festool says.
View remdds's profile
remdds
29 posts in 2651 days
#14 posted 05-17-2015 01:41 PM
AlaskaGuy
#15 posted 05-17-2015 04:29 PM
Festool does not guarantee the ends are a perfectly square.
