Forum topic by Muzzy17 | posted 05-13-2015 06:05 PM | 770 views | 0 times favorited | 6 replies | ![]() |
I am limited to outdoor work for my woodwoorking and looking for opinions on the simplest finish for either outdoor or indoor furniture. Planing on getting into Adriondack chairs, birdhouses and live edge slab stuff. -- Deep rooted Southern Boy and set in my ways! |
#1 posted 05-13-2015 08:45 PM |
I prefer spar urethane for outdoor use. It is extremely water-resistant. You might not want a varnish for Adirondack stuff though. For that I would probably use a deck stain. Or boiled linseed oil. -- Logan |
#2 posted 05-13-2015 11:03 PM |
Simplest finish is probably something like Thompson’s Water Seal. Brush on, wipe off, done. But it has to be reapplied periodically. Any outdoor varnish would work too. Spar varnish/exterior varnish are the same thing. |
#3 posted 05-13-2015 11:25 PM |
Spar or marine varnish does not last. That’s why wooden boat owners scrape/sand/varnish every season. Simplest would be a transparent stain, Thompsons, or something that does not build up a film. Solid stain and paint or clear varnish will flake and peel requiring the most work to refresh. Using something Like Thompsons once or twice a season. will be the easiest to deal with in the long run. Birdhouses should be painted or stained natural colors and don’t need much touch up. I put asphalt shingle scrap on the roof. Perches on the front of the house are also unnecessary and just invites predators. Put the front on with a couple of drywall screws so you can clean them out at the end of the year. |
#4 posted 05-14-2015 01:44 AM |
Thanks for the reply fellers. -- Deep rooted Southern Boy and set in my ways! |
#5 posted 05-14-2015 02:54 AM |
I’ve had good luck with ‘Sikkens Cetol 1’ on hot tub and outdoor furniture, I believe it was formulated to be used as deck stain, under no circumstances should it be used indoors. |
#6 posted 05-14-2015 03:09 AM |
The easiest is just a good oil based paint or even latex. -- Brad, Texas, https://www.youtube.com/user/tonkatoytruck/feed |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2199 |
Coffee Lounge
8842 |
