Help setting Rockwell 13" planer knives
Forum topic by builtinabarn posted 101 days ago 352 views 0 times favorited 6 replies Add to Favorites Watch
View builtinabarn's profile
builtinabarn
81 posts in 283 days
101 days ago
Topic tags/keywords: jig question planer
Im changes the planer knives out on an older (1980’s) 13” rockwell planer that I just recently bought from a guy. I used my delta height setting tool to set the blades in the hub, but I think it set the blades to high. can any one help me with this. I dont have a manual on this unit so Im kinda lost. I guess I can adjust the blades lower but I will have to make a jig to set them equally every time until It seems like the right height. Id rather just know the correct height and be done with it already. HELP PLEASE.
-- Built in a Barn Bob
17020 posts in 475 days
101 days ago
Hey Bob
you could add shims to your old delta height setting tool until it cuts properly.
-- Jim from Heirloom Woodshop, custom furniture, woodworking school, heirloomwoodshop.com
builtinabarn
101 days ago
Yes, Jim, thats a good idea, but I would still like to know the proper height setting by the manufacturer.
Thanks
View roman's profile
roman
1125 posts in 791 days
101 days ago
phone the manufacturer?
maybe they might send you a pdf manual
builtinabarn
101 days ago
I actually acquired a manual but it only states to use the planer blade setter that came with the unit. Thats no help to me cuz I dont have the original blade setter
View rick3ddd's profile
rick3ddd
58 posts in 659 days
99 days ago
As one who worls on machines a general rule of thumb is the bevel on the blade would be even with the cutterhead. You could also figure out the height of the feed rollers and work backward from the manual as they typically are around .030” below the cutting circle.
Not familair with “Delta height setting tool” Standard practice is to reference off the cutter head and all other settings are from the cutting circle or tip of the knife. Once you figure out the cutting circle and set everything you will only have to reference the knives to the same cutting circle even if you change your knife bevel.
-- Whatever!
builtinabarn
97 days ago
I did finally figure that out Rick. Thanks for all the help guys
