How To Create These Faux Marks?
Forum topic by bowtiefoster posted 05-13-2015 03:53 PM 819 views 0 times favorited 9 replies Add to Favorites Watch
View bowtiefoster's profile
5 posts in 1071 days
05-13-2015 03:53 PM
Topic tags/keywords: reclaimed faux finish
I know this piece isn’t real reclaimed wood and the marks are faux – how do they do it? How do they get the marks and the smooth edges? Also – would you say it has a glossy finish? Any help would be greatly appreciated!
9 replies so far
View JoeinGa's profile
7733 posts in 1940 days
#1 posted 05-13-2015 11:06 PM
Chisels, axes, hatchets, screwdrivers, pocket knives, claw hammer, and anything else you can grab to beat the wood with.
And I’m guessing it’s a satin finish.
15249 posts in 2551 days
#2 posted 05-13-2015 11:10 PM
The long ‘creases’ have me flummoxed.
View jerryminer's profile
909 posts in 1374 days
#3 posted 05-13-2015 11:15 PM
The long creases have me flummoxed.
- Smitty_Cabinetshop
I use a veining tool—-a type of carving chisel that is V-shaped—-but you can make a scratch with an awl or screwdriver, then widen and deepen with a chisel.
View dhazelton's profile
2720 posts in 2229 days
#4 posted 05-13-2015 11:19 PM
In art school I did some linoleum prints. You use a vee-shaped cutter and just push it through the material. You could get one for just a couple of bucks at an art supply store. Then use black paint or a marker to fill the groove, then sand to clean up the top surface. Looks like semi-gloss to me. The holes are probably from an ice pick type tool, or a small nail set driven pretty hard with a hammer.
When you pay twelve cents a day you can go nuts with hand work like this.
View Ghidrah's profile
667 posts in 1155 days
#5 posted 05-14-2015 12:18 AM
I saw a crew distressing floors with old bent and rusty nails and heavy chains and lawn rollers
-- I meant to do that!
View felkadelic's profile
218 posts in 2473 days
#6 posted 05-14-2015 12:23 AM
There was a recent episode of This Old House that showed the steps in distressing wallboards. As I recall they roughed up the boards pretty good with a tool that essentially left random imperfections in the wood. Then there was a multi-step finishing process to give an aged, worn look. Pretty interesting to see, even though the end result isn’t appealing to me in the least.
#7 posted 05-14-2015 01:17 AM
To me that’s like buying pre stressed stone washed pants. I prefer new stiffer and scratchier than hell dungarees that I can wreck on my own.
View Makarov's profile
102 posts in 1738 days
#8 posted 05-14-2015 01:48 AM
looks to me like they could be made with a hatchet.
-- "Complexity is easy; Simplicity is difficult." Georgy Shragin Designer of ppsh41 sub machine gun
View ElChe's profile
630 posts in 1269 days
#9 posted 05-14-2015 02:00 AM
+1 on veining tool. Or use marking knife to mark out the crease and then use tip of chisel to remove material between the marked lines.
